Cab door seal dk45s
/ Cab door seal dk45s #1
Kendrick
Gold Member
Vermont
DK45S(Cab)
I have a dk45s cab that the door caught on a limb and pulled out the door piston and has damaged the door seal. Does anyone know if that's repairable or a door replacement?
/ Cab door seal dk45s #2
Kendrick, it's kind of hard to tell where the seal is and how it's installed by your pics since I'm not familiar with your tractor. I did try to locate the seal on a parts breakdown but no luck. It appears that the seal has just been dislocated and could be reseated. If the seal is between the glass and frame it's possible that you could take the door to a auto body shop and have them put the seal back in or replace it with a universal one.
/ Cab door seal dk45s #3
I was just looking at the seal on a door for a 2009 BobCat CT450 which is really a DK50SE C. I think it might be the same cab but double check your year. The part is actually just called a rubber and is shown only as a small section, but Kioti P/N T4145-82521 if I'm correct. I can check with my parts place down the road because she might have mentioned yesterday that there was a new part number on that one, but they should still match up. That looks fixable on yours, but, here in Canada, that seal is about $55 CDN so maybe $40 USD. It is back ordered here at some places but available through others.
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
Decorative Mermaid Statue (A61569)
Decorative Mermaid...
Clark CGP40 Forklift (A61166)
Clark CGP40...
(24) Ratchet Tie Down with Toolbox (A61166)
(24) Ratchet Tie...
2008 Freightliner B2 Bus, VIN # 4UZABRDJ88CZ17960 (A61165)
2008 Freightliner...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
