Round Bale Fires
/ Round Bale Fires #1
EddieWalker
Epic Contributor
Tyler, Texas
Several, all used and abused.
I've heard about square bales spontaneously combusting if they are stored too soon after baling. Does this happen with round bales too?
/ Round Bale Fires #2
It can if they are stacked on ends in a tight barn. Let them sit outside through sweat period, then probe for moisture & temp with a hand held. Then put them in barn. Sitting outside, even in a few rains (net wrapped) will only slightly hurt the feed quality, so whats the harm in letting them sit a few days
If you bale them with a real time moisture read out and they are all consistently under 14%, then they can be put in a barn.
Or buy a crop saver applicator. I had one and used it for a year. Many customers complained about the smell or the preservative, so I stopped using it and went back to making DRY hay for feed.
/ Round Bale Fires #3
Seen two barns burn from hay fires… racing to get the hay in to beat the weather in both cases.
/ Round Bale Fires
Thanks. I haven't built the hay barn yet, so I'm just curious what might happen. It will be a loafing shed type building that will be open along the front. With the price of hay climbing so quickly, I'm thinking that I need to protect it from the elements.
/ Round Bale Fires #5
just pencil it out. See if barn is worth the price. Net wrap is the round balers best friend. It allows for rain without significant damage.
/ Round Bale Fires #6
A big sheet of plastic might save your barn if you are pushing it to get under cover.....
/ Round Bale Fires #7
All my rd bales are netwrapped & stored outside. Over the yrs I've sold a lot of these stored outside bales to horse owners. Key is to store on gravel or well drained soil & don't allow rounded sides to touch. It also helps to place the rows North to South for more availability to Sunshine
/ Round Bale Fires #8
Location, location, location.
We get a lot more rain & cold damp days up here.
/ Round Bale Fires #9
That is very true but I was replying to Eddie Walkers question who is OP of this thread who lives around 100 miles from me not you.
/ Round Bale Fires #10
Yep, you’re right. (y)
I don’t know if TX has “rainy” parts of the state….
/ Round Bale Fires #11
In my part of the country any hay left outdoors is junk.
I've heard numerous people try and tell me that only the "outside few inches" was bad.
So 10 inches on the outside of a good sized round bale is roughly 20% of the bale.
Then the moisture and mold that forms were the bale has wicked moisture up from the ground
and now you've got a half a bale and your animal has a good chance of ingesting mold toxins.
Yep, you've really saved by outside storage. Net wrap or twine it doesn't matter.
Here if you are going to store outside you have to treat dry hay just like baleage and plastic wrap it.
/ Round Bale Fires #12
Any shape bale put up too wet can combust. Small squares were commonly associated with this since they were baled and taken to barn immediately and stacked tightly in a barn.
Most round bales are left in the field for a few days before being put in a barn, in some cases they get left where the baler drops them until fed out.
I started doing round bale silage/haylage. Too few hot dry days to make good hay, nice being able to not worry about it being dry enough. Plastic is an expense but cows eat 100% of the bale and it's stored outdoors.
Net wrapped dry hay would fair the best stored outdoors here.
/ Round Bale Fires
East Texas gets a fair amount of rain. A normal year is close to 4 feet of rain. Every year we get at least one storm that drops 3 inches. 5 inches in one night is my personal record. 8 inches in three days didn't even break any records.
/ Round Bale Fires #14
I was in Gilmer yesterday.
/ Round Bale Fires
Gilmer is less then half an hour from my place.
/ Round Bale Fires #16
I leave them outside only a few days after baling to sweat.
Would never leave them out other than hot summer days.
Agree that leaving them out on ground for long periods ruins them
I saw a few barns burn and everytime it was bales put away too soon or a roof leak.
/ Round Bale Fires #17
It is not the shape of the bale, but the moisture content. I recall in the 50's spreading salt in the mow of square bales that may have been too damp and possibly cause spontaneous combustion.
One cure seemed to be pack the bales tighter to keep out Oxygen? Likely untrue.
/ Round Bale Fires #18
It will happen with any bales when the hay is too “wet”(green and not dried sufficiently in the sun). And if they don’t get hot and combust, they will probably mold from the moisture.
/ Round Bale Fires #19
Any hay baled to wet can catch fire weather stored inside or outside, if it’s going to start burning it usually takes about 6 weeks before it happens. Yes spreading salt on baled hay used to be a very common practice, I really have no idea if it actually prevented any fires. Now days most farmers use moisture testers to see what the actual moisture content might be.
2013 Caterpillar 420F 4x4 Extendahoe Loader Backhoe (A64194)
2013 Caterpillar...
2007 Toyota Tundra 4x4 Ext. Cab Pickup Truck (A64556)
2007 Toyota Tundra...
2017 CATERPILLAR 259D SKID STEER (A65053)
2017 CATERPILLAR...
JLG TELESCOPIC FORKLIFT (A64279)
JLG TELESCOPIC...
2008 GMC 3500 HD 4x4 Ext. Cab 9Ft. Flatbed Truck (A64194)
2008 GMC 3500 HD...
2017 Ford E-450 Super Duty Shuttle Bus (A64556)
2017 Ford E-450...
