JD 1050 major spill of motor oil
   / JD 1050 major spill of motor oil #1
farmer marx
Member
brattleboro VT
deere la105
To make it quick: I saw burned motor oil spraying out of an overflow rubber tube coming from the area of the fuel injectors.
I turned it off and wanted to check the oil level. As soon as I took off the cap, the oil came out like tilting a gallon jug on the side at once,
a jet 3-4 inch long and a lot of it.
It clearly came from up higher because it stopped when it reached the level of the tank opening.
Obviously there is a big problem somewhere, but what is the most likely cause?
Is there anybody that has a suggestion?
Thank you in advance.
Farmer Marx
   / JD 1050 major spill of motor oil #2
If you don't have a diesel smell my guess is a leaky seal on your hydraulic pump. Due to the quantity of hydraulic fluid in a tractor you may not notice if it's a couple quarts low but you'll sure notice if your oil pan is a couple high.
   / JD 1050 major spill of motor oil #3
Farmer Marx
You'll have to determine if it is diesel or hydraulic fluid getting into the engine oil. The 3 main culprits are usually fuel lift pump, injector pump or hydraulic pump.
Thank you. The hydraulic fluid tank is full so I would exclude that. I need to find out about diesel and injectors. Thanks again.
Thank you, most likely I will need an expert to look into it. I dont' have enough experience for this level of complexity but I will do what I can to try to eliminate some of the possible causes. Your insight was very helpful.
   / JD 1050 major spill of motor oil #6
I would be sure to check the fuel lift pump (if equipped) first. It is the easiest and cheapest to fix of the three.
I will check the service manual. I just got a new copy after the guy who came to my house to service my tractor 6 months ago stole the original.
New/Unused 20ft x 20ft Container Shelter (A44391)
New/Unused 20ft x...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A43003)
2019 KENWORTH T680...
Toro Z-Master 60in Zero Turn Mower (A44572)
Toro Z-Master 60in...
2015 Ford Fusion SE Sedan (A44572)
2015 Ford Fusion...
Scag Tiger Cat (A44502)
Scag Tiger Cat...
2012 CHARLTON & HILL TDS-1700 PORTABLE SAND CONVEYOR (A45333)
2012 CHARLTON &...
