If You Were To Get A New 6 Ft Finish Mower - What Would You get?
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #1
wirlybird
Gold Member
Oklahoma
John Deere 3038 E, John Deere 3032E, John Deere 756, John Deere X585, John Deere 332
Ok, I'll clarify a little.
Considering replacing my 6 foot finish mower.
The main thing I would like is not only a rear discharge but one with a good discharge pattern. Not one that discharges in clumps like mine does.
Mine has a "chute" type discharge at the rear so it restricts the discharge some and causes clumping. I first took the chains off and it was a little better then took the chute off and it is much better but it also blasts the left rear wheel with clippings turning it into a big green grass ball!
I've seen a few that look like they discharge across the whole back of the mower. Wondering how well these work?
It also needs to be a pretty heavy duty mower. Not so much blade wise but just overall construction.
The areas it will be used on are not perfectly smooth!
Thanks for suggestions. Used in great shape is also an option.
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #2
The Brush Hog 6ft RFM I had was rear discharge, left a gorgeous cut on uneven yard, and was built as thick and heavy as a rotary cutter. If only my tractor could have pulled it faster. 25 hp not enough if you have hills.
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #3
the only mower that I REALLY WANT at this point is a Ventrac 4520 (not sure of the specific model yet)
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #4
In 2009 I bought a phoenix 6' 3 pt hitch finishing mower for my Kubota L3800. No complaints. I was a little too rough with it at first so I had to replace wheel forks a couple of times and the belt tightening system had to be rebuilt but works fine now. I would buy again. Nice thing about rear discharge is the underside of deck does not need as much clean up as a side discharge. :D Getting the blades on and off requires a 3/4" breaker bar.
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #5
I have the 7' estate finishing mower ( rear discharge ) from Agri-Supply and it leaves a nice finish as it discharges all the way across the rear, but unless you just want a finish mower, a nice 60" zero turn lawn mower will get the chore done faster, I have a 52" and a 60" Gravely ZT's and they are what I mostly use.
Is it Brush hog or Bush hog? Model number by chance? Not finding much yet but like the sound of it.
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #7
I'd get another landpride, mine won't die after 30 years
I considered a large Z turn but first thing is I won't use it anywhere else.
I also tried one out on one of these areas and it was a rough ride.
I'll look at Agri. 7 is too big since I can't trailer it! But a 6 is good.
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #9
I have an old big bee that is a rear discharge , It cuts very good and does not clump . My original woods was a side discharge and it was terrible For leaving rows of grass, cutting more often helps alot but with gas prices it is costly. We have had so much rain i cant keep up with it,
Yea, diesel is out of control. Cost me more to fill two gas cans yesterday than it used to cost to fill my Tahoe!
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #11
I've had my Woods RD 72 for two years and I have no complaints on it. It is a discontinued model but they have two newer 72" models.
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #13
LandPride i show I would go if I were to be looking for a finish mower. Sold my bought used 6' last year for what I paid for it 30 years ago. Other than a few rusty spots where the paint had come off it still looked like the day I got it and all I ever did was put a belt on 2 years ago and a new set of blades.
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #14
I had a 5' Woods finish mower and thought about going bigger. It cut fine but was slow and left me with a need to trim. Got a Ferris 3200 61" ZT and cut the mowing/trimming time down from 5+ hours to < 2 hours with no trimming. It has a full coil-over suspension so they aren't as bouncy and jarring as others I test drove. Was cutting at about 3mph and now closer to 10+mph and don't need to slow down except for the turns and can zip around everything with ease. I didn't want two items to maintain but needed to find more time each week with work/kids and was the biggest bang for the buck. The Woods was a nice mower. I would have preferred one with better wheels/rollers if I was getting another to help avoid scalping.
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #15
Probably not what you were looking for, but this is my 6' finish mower.
I can mow at 13 mph, so there's that... :)
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #16
Sitrex, Italian made and very reliable.
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #17
Everybody talking about how fast they can mow. I didn't move to the country and buy a bunch of land to spend as little time as possible out on it. I put on my noise canceling headphones and some music and I can stay out there all day. It reminds me of golfers who brag about how fast they can play 18 holes. And if I ever decide I don't have time to mow it, I'll just let it grow.
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #18
I had a thread here about restoring some old finish mowers. One was a Befco 7' Rear Discharge that was built like a tank. Another was a Modern Manufacturing 6' Rear Discharge. As far as I can tell, it's identical to the one Northern Tool sells: NorTrac 3-Pt. PTO Finish Mower 72in. Cutting Width | Northern Tool
Everything looks identical and I was able to get new blades from Northern. I think they make them for Northern. I can't say it was as stout as the Befco, but it seemed reasonably solid. I have a belly mower and really don't have terrain suited for a rear mount, plus I'm not sure my machine could have powered it. Sold it for $800, in OK shape, but not super great.
Not sure if that has the same chute type discharge you were mentioning, but it's nearly full width and has chains.
I can't mow fast. Too rough and too many hills and turns.
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #19
I have a land pride 1672 RFM. Wonderful mower. After 5 years, zero issues or complaints.
/ If You Were To Get A New 6 Ft Finish Mower - What Would You get? #20
I use my JD 570 to mow my "lawns". I have two acres of lawn. If I traveled much over 3-4 mph - a seat belt would not keep me on the mower. About 80% of my "lawns" are mowed field grass. And with all the associated bumps, dips, ruts - etc.
It takes me a full two hours to mow my two acres of lawns.
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
2016 FREIGHTLINER CASCADIA 125 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A59906)
2016 FREIGHTLINER...
2014 FORD F150 4X4 PICKUP TRUCK (A59906)
2014 FORD F150 4X4...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2018 Volvo VNL 760 T/A Sleeper Cab Truck Tractor (A61568)
2018 Volvo VNL 760...
