My Place: a CAT, Mahindra, and Ducks
   / My Place: a CAT, Mahindra, and Ducks
Price your lumber like the lumber yard and there should be enough 2x4s in that "toothpick " to pay for the mill !!
The mill has been paid for going on 4 years now.
hugs, Brandi
I took the backhoe off of my tractor so I could use the landplane in helping out with the sawmill shed pad. But I miss the weight of the backhoe. I don't like curling a log off of a trailer and getting that "my butt is floating" feeling.
So I cut a Red oak down to 9 feet and squared in up to a 15 inch square. My calculations and the seat of my pants say the landplane now weighs about what the backhoe does.
hugs, Brandi
   / My Place: a CAT, Mahindra, and Ducks #556
So I cut a Red oak down to 9 feet and squared in up to a 15 inch square. My calculations and the seat of my pants say the landplane now weighs about what the backhoe does.View attachment 741773View attachment 741774
hugs, Brandi
I have that same landplane, but in brown (bought it at a Kubota/Land Pride dealer).
Is your 7' or 8'? Hard to tell in the pic. Mine is the 7'. Wish I had an 8'
CT
CT
CT,
The key to the width was in the caption.:ninja: The Red Oak is 9 feet wide, a little wider (second photo) than the landplane at 8 feet.;) Where are you located in LA.?
hugs, Brandi
   / My Place: a CAT, Mahindra, and Ducks #558
CT,
hugs, Brandi
I was reading this in the earlier hours of the day. My context clues were not on point! Though using your tractor as a gauge, I knew it was at least 7'. :cool:
Natchitoches, LA
CT
Natchitoches, LA
CT
Well howdy neighbor!
Yeah, I wanted it wide enough to cover the rear tires. Lower gears are a must.
hugs, Brandi
I think I got the sawmill shed pad leveled. I will find out when my concrete guy stops by with his rotary laser.
Now I have decided to take out more trees behind it so I can have more room to drive behind it. So the CAT will get to do more tree carnage with its 28 inch digging bucket.
hugs, Brandi
2007 INTERNATIONAL 9400I TANDEM AXLE DAY CAB (A56129)
2007 INTERNATIONAL...
500LB Livestock Galvanized Creep Feeder (A55301)
500LB Livestock...
PULL TYPE CONCESSION STAND (A54757)
PULL TYPE...
Giyi Mini Side Shift Forks (A53316)
Giyi Mini Side...
Case 1083 20ft Corn Head (A55301)
Case 1083 20ft...
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
