any informatiobn on LandTrac Long Agribusiness Lt280D tractor?
   / any informatiobn on LandTrac Long Agribusiness Lt280D tractor? #1
micali
long agribusiness lt280d
Hello I have a LT 280D that I need some information on. I have scoured the web but haven't come across any definitive information on this tractor.
I would like to know
1. Where do I fill the Hyd fluid at.
2. What type of oil does this engine take. Mitsubishi SL4 diesel. I read somewhere that it takes SAE 30 but I can't find that info now.
3. What types of fluid does this tractor take
I know it is not hydro-static. It has a clutch.
There is some more information on Tractordata.com but I can't post links until I have three posts. I was told that the Montana 2740 is the identical replacement for my tractor less the engine.
20190411_191547.jpg20190411_191557.jpg20190411_191609.jpg20190411_191615.jpg20190411_191645.jpg
Yep, that's what I tried to post earlier. I wish it had more valuable info but sadly it doesn't.
I just found this. This is what I was talking about before. From the chart and my geographical location it appears SAE 30 is correct.
   / any informatiobn on LandTrac Long Agribusiness Lt280D tractor? #5
I don't know where you are but 15w 40 or 5w40 is ok.......
   / any informatiobn on LandTrac Long Agribusiness Lt280D tractor? #9
If its the same as a Montana you should be able to get a book or pfd from them.....
   / any informatiobn on LandTrac Long Agribusiness Lt280D tractor? #10
Not that you won't get the info here, but the name plate shows this as a Korean made tractor. This is the Chinese section. I use 15w40 diesel rated oil for my DF for 10 plus years.
   / any informatiobn on LandTrac Long Agribusiness Lt280D tractor? #11
Your LT280D was built by LG, a korean company which has become LS Tractor.
LandTrac 28 DTC | Tractor & Construction Plant Wiki | Fandom
TractorData.com LS LT28D tractor information
The oil mentioned 5W40 or 15W40 for diesel engines will work fine as well as universal hydraulic oil sold in all tractor supply stores.
The hydraulic level site glass is shown in your first pic just left of the PTO shaft. I believe the fill plug is about a foot above the site glass just to the left.
Of course the 280D is a discontinued model but the engine is still popular and is used in many other tractors. I don't know if LS kept records of the LG tractors but it wouldn't hurt to ask. Here is their contact page.
CONTACT – LS Tractor USA
Thanks for the info. are you talking about the single bolt basically straight up and to the left? So, any universal hydraulic fluid? So does the transmission, and axels use the same fluid? or is all of that seperate? I know that the main line for bucket hydraulics attaches on the right side of the PTO. Thanks for your help.
will it hurt to mix the hydraulic oil? I have no clue what is existing.
So I found out a lot of info on this tractor. You can fill the tractor at each axel and final drive and the main sump. I just needed to remove the line on the right corner to fill with UTF. Since the PS, trans and lifts all use the main sump for fluid I put in abut 5 gallons there, after draining everything of course, and the axels and final drives. Now my issue is in med gear I get this awful grinding noise only. The High and low gears sound find. I'm wondering if that is the transmission that is causing the noise? thanks again for every ones responses.
   / any informatiobn on LandTrac Long Agribusiness Lt280D tractor? #15
I have the same tractor...can you tell me where you found all that info?
2007 Ford E350 (A55973)
2007 Ford E350...
Kubota U55-4 (A57148)
2022 KOMATSU WA500-8 WHEEL LOADER (A60429)
2022 KOMATSU...
2016 Chevy Silverado Z71 4wd 5.3L V8 (A56438)
2016 Chevy...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58214)
2011 MULTIQUIP...
Massey Ferguson 1745 Hesston series (A53317)
Massey Ferguson...
