Amazingly accurate but inexpensive inclinometer
   / Amazingly accurate but inexpensive inclinometer #1
etpm
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
I decided that for some of the work I will be doing in the near future a digital inclinometer would be a big help. I bought this one: https://www.amazon.com/dp/B08L5VYG1M?psc=1&ref=ppx_yo2ov_dt_b_product_details . Only 20 bucks from Amazon. It has many features besides showing the angle. It shows slope in inches per foot or mm per meter. The inches per foot shows fractions of an inch per foot which I will not use. I will use the mm per meter if I need the slope and then convert it to decimal inches per foot. But the accuracy is really amazing for such an inexpensive device. In my machine shop I can check angles to a very high degree of accuracy so I decided to check this device. It is advertised being accurate to a tenth of a degree. 1 degree results in a slope of approximately .0175" per inch. So one tenth of a degree would be .0175 in 10 inches. Just slightly more than 1/64". Or 2/3 of 1/32" in a foot. That's pretty good. But the inclinometer I was sent is consistently accurate and repeatable to 1/20 degree. Or about .0009" per inch. Or .0105 inches per foot. I checked mine from 0 to 25 degrees. The surface plate I used to check the thing has 20 millionths of an inch maximum deviation from perfectly flat over the whole surface. The gage blocks I used have a plus 8 millionths and minus 4 millionths of an inch deviation from nominal. The sine bar I used is, alas, only 50 millionths from the nominal 5 inch spacing of the rolls, but is within 20 millionths of being flat. I know, over the top. But these are the tools I have easily available and I was curious. I am still amazed at the accuracy of this inexpensive device.
Eric
The butt pucker factor is a pretty good inclinometer.
I suppose, when sitting in the seat, it is. My project involves welding new bushings onto the arms of my FEL in order to change the pivot point of the bucket to get more curl. I'm not gonna sit on the ends of the FEL arms and gauge how much my sphincter puckers on each arm to determine if the new bushings are in line before welding. I don't think I have the accuracy or precision in certain muscles. But some folks have a very well calibrated chocolate starfish and may be able to do this. Maybe you are one of these people. You are welcome to come out to my place and try. I'll be interested to watch the process and will even post a video of it if is appropriate. I'll even hold your beer.
Eric
   / Amazingly accurate but inexpensive inclinometer #4
Eric
You never stated your purpose so it’s not unreasonable to believe that you wanted it for operating on slopes.
   / Amazingly accurate but inexpensive inclinometer #6
I have one and have used it on a number of projects in the machine shop to set up parts for machining in the mill. Its a very handy tool.
   / Amazingly accurate but inexpensive inclinometer #7
Millionths of an inch, and I'm being very careful using the little marks on my tape measure.:LOL:
   / Amazingly accurate but inexpensive inclinometer #8
Download free app on you smart phone
I have a Suunto inclinometer I use out in the woods when truing not to hit anything when cutting standing trees.
I have and use "clinometer" app on my pocket phone It has all sorts of bells and whistles. My first phone did have straight sides, so the top and bottom edges were the most reliable. My present phone (Moto G7) has straight sides and a flat back. Works fine.
I did a bit of "reality test" at first. Held the phone in the four jaw chuck on the lathe, and then indexed the spindle in every way but Sunday. I couldn't fault the display value for accuracy or repeatability. 2 place decimal degrees.
Close enough for the girls I go out with.
   / Amazingly accurate but inexpensive inclinometer #9
So many factors influence stability. Over 15 causes concern and watch my loading and implements. 20 slow and small moves. No batteries and always on and onboard. Second one does inclination. Wireless sphincter connection.
Digital one in shop helps with bending and fabrication.
   / Amazingly accurate but inexpensive inclinometer #10
Commercial and better loaders use a link or four link curl arms to improve articulation and power.
2021 CATERPILLAR 306 CR EXCAVATOR (A52709)
2021 CATERPILLAR...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
1459 (A57192)
1459 (A57192)
2022 Behnke Trailer (A55973)
2022 Behnke...
2019 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2019 Ford F-550...
2015 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A56858)
2015 Chevrolet...
