M4D-071 Maximum Operating Weight
/ M4D-071 Maximum Operating Weight #1
Iowa Hillbilly
The Hills of Eastern Iowa
Case 2590, CIH 685, Case 400
Does anyone know the maximum operating weight for a Kubota M4D-071? I'm guessing its in the operators manual, but unfortunately I can't find a free download for it. :(
/ M4D-071 Maximum Operating Weight #2
Manuals don’t give a total max operating weight. I looked at one of my tractor’s manuals. They give the base weight, but beyond that limits are spread through the manual. Do not use liquid ballast beyond xxx per tire (there is a different number for each size). Do not add front ballast beyond yyy. Do not add rear wheel weights beyond zzz per wheel. There is no number given you can use to go to a scale and determine if you’re overweight. There is a number given as never exceed for each tire size.
Thanks for checking for me. I was looking at the manuals for a couple of competing tractors and they both had that figure so I figured Kubota would too. I guess different manufacturers approach this differently.
/ M4D-071 Maximum Operating Weight #4
Cast wheels, fluid, loader arms with bucket is going to be between 9 & 10 K on my estimate.
/ M4D-071 Maximum Operating Weight #5
My 2009 Kubota M6040 has a base weight of 4785#. I've added - FEL, grapple, RimGuard & rear blade. It now weighs 10,100#. My Op Manual lists NO max operating weight.
The way it works. The Op Manual DOES list max weight for implements.
You need to get your hands on an Op Manual for your tractor. Try your local dealership.
/ M4D-071 Maximum Operating Weight #6
What are you trying to do with it at max weight?
/ M4D-071 Maximum Operating Weight #7
www.kubotabooks.com
Always puzzled me how anyone can buy a tractor for many thousands of dollars and not even have an owners manual.
I don't own an M4D-071. I'm trying to compare it to other tractors to decide which one best fits my needs to decide which one to purchase. I've been able to get free downloads of the manuals for two others, which I have read, but not for the M4D-071. I'd rather not purchase the owners manual without owning the tractor especially when I might buy a model from a different manufacturer.
/ M4D-071 Maximum Operating Weight #11
I would not ever buy a used tractor without the owners manual being included, especially a late model on and I'd also want all the maintenance records as well When I sell an implement or tractor, I ALWAYS include all the documentation with it. How I roll. That includes all the receipts for any parts or filters or anything I purchased for it. Buying a tractor without any documentation is like putting on your shoes with no socks.
/ M4D-071 Maximum Operating Weight #12
I want to use a 3pt no till drill for pasture reseeding. Something like this 3P606NT Compact Drills | Land Pride
With the tractor ballasted that's getting pretty heavy for something in this size range.
Both my M9's will easily handle that and larger. Not that I'd buy one new, I'd peruse Tractor House for a good used one first. Because a drill isn't an often used implement, better to buy used than new.
/ M4D-071 Maximum Operating Weight #13
I, also, have often wondered what happens to all the Owners Manuals/Operators Manuals. There HAS to be one with a new tractor. When I traded in my Ford 1700 - the Op Manual and all my service records when with the tractor. I KNOW the new owner got them. I had my email address and phone # on the inside cover page. He called me to answer a couple questions. I was very pleased to see that he read these documents. The 1982 Ford 1700 that I purchased, brand new, is still running great and is being properly serviced.
/ M4D-071 Maximum Operating Weight #14
Drill is one ton empty and two ton full.
3307 lift capacilty. (1.5 ton)
Might just be enough tractor if you don't plan on filling the drill to max weight.
/ M4D-071 Maximum Operating Weight #15
/ M4D-071 Maximum Operating Weight #16
You don't need the tires filled either. R1's will do just fine. Remember, the more weight you add (to the rear tires) the more compaction you get. Myself, I never load my tires with anything except air. For me loaded rears are a big no as they crush my hay plants and reduce yield.
/ M4D-071 Maximum Operating Weight #17
Looking at the specs, I think you’re going to be very light on the front end with that drill.
I'm on some pretty serious slopes, so I really want the ballast for extra stability. As long as the tire's psi is the same shouldn't compaction be the same ballasted or not?
I could live with not filling the drill all the way up. 1000lbs of seed or so is all I would expect to need in one shot, but I'm wondering if with ballasted tires and 3300lb on the back if I'd be overloading the machine.
I'm comparing the M4D-071 against the TYM T754. It lists a maximum operating weight of 12566lbs. The M4D-071 has a tighter turning radius, which would be handy for me though.
/ M4D-071 Maximum Operating Weight #20
NO. The heavier the tire and rim are, the more compaction you have. I do slopes too. I just shift into FWA.
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2021 ISUZU NPR (INOPERABLE) (A60736)
2021 ISUZU NPR...
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
2018 Komatsu D61PX Crawler Tractor Dozer (A59228)
2018 Komatsu D61PX...
CFG Industrail MX15RX (A53317)
CFG Industrail...
