3pt drawbar?
/ 3pt drawbar? #1
SDAnnette
San Diego
Case D45
Hello,
This attachment came with my case D45 tractor when I bought it used. It appears to be some kind of 3pt attachment with a drawbar. What is puzzling me is why it is rectangular, rather than triangular?
I was going to use this to haul a woodmaxx 9900 PTO drive wood chipper.
It doesn't look like a quick connect, but I think it will do the trick for my purpose.
Any comments appreciated.
/ 3pt drawbar? #2
It appears to be a variation of what most people call a "Quick Hitch" (QH).... Its rectangular so the locking lever/arms/bars can function in straight up/down motion...If it were triangular it would require you to wrestle with hardware when making the 3PH connections...
/ 3pt drawbar? #4
The bar with the holes in it is intended as a drawbar for towed implements with a clevis hitch. Remove it, then you can attach your quick hitch to any compatible 3-point implement.
Bruce
/ 3pt drawbar? #5
It is a quick hitch, they are rectangular: 3 point quick hitch - Image Search
Yours may be home made
/ 3pt drawbar? #7
It looks like a Harbor Freight quick hitch. I had one, useful for a few years and then it came apart.
/ 3pt drawbar?
Thank you everyone. I really appreciate the info.
New/Unused 7ft Double Chain Sling (A65583)
New/Unused 7ft...
New Holland LB75B Backhoe (A62613)
New Holland LB75B...
Freightliner Columbia (A63689)
Freightliner...
2003 GMC C4500 Crew Cab Dump (A62613)
2003 GMC C4500...
2015 KOMATSU PC170LC-10 EXCAVATOR (A62129)
2015 KOMATSU...
STORAGE FEES (A59914)
