Massey Ferguson 1526 FEL and 3 pth chatter in the loader valve??
   / Massey Ferguson 1526 FEL and 3 pth chatter in the loader valve??
Sounds like the relief valve is chattering. Is this something that started recently? Does it seem like you can lift less with loader or 3 point? Not common but possibly the spring took a set in the system relief changing the opening pressure which may or may not contribute to the chatter.
does your loader valve have the power beyond sleeve that requires an O-ring on the nose to seal? If yes another possibility is this O-ring is starting to fail close to relief pressure so leaks some oil pressure drops relief closes , cycle repeats.
So I pulled the pressure relief valve out added a .060” shim and got the pressure from 1750 to about 2000 ish and noise is gone I can lift a full load of top soil now no problem and I can curl the bucket and bottom out cylinder and no noise at all. I guess the prv was out of adjustment and needed to be bumped up a bit to get it to not chatter
   / Massey Ferguson 1526 FEL and 3 pth chatter in the loader valve?? #14
GB
I would say your perseverance has solved your problem and that yes at 2000 PSI you very close to specs and I would leave well enough alone.
congrats on finding a simple solution - repair.
just a thought but possibly check the pressure again after using the loader for several hours just to see if the pressure is still same or very similar.
GB
Thanks oldnslo I will do that tomorrow thanks for the help and thanks to others that helped as well. This is a great site
   / Massey Ferguson 1526 FEL and 3 pth chatter in the loader valve?? #16
Glad you were able to figure it out!! And thank you for sharing your process!! Always invaluable for others to reference..
Is the hydraulic fluid nice and clear now?
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Forks...
AIR HOSES & BEAD SETTER (A55745)
AIR HOSES & BEAD...
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
PARTS ROOM W/SHELVES (A55745)
PARTS ROOM...
1999 Volvo VN Truck, VIN # 4VG7BBRFXXN772814 (A54865)
1999 Volvo VN...
PALLET OF SCAFFOLDING (APPROX. 19 PC) (A52706)
PALLET OF...
