Poat hole digger, Did Sumpin'
   / Poat hole digger, Did Sumpin' #1
Raul-02
the armpit of the entire universe New Jersey
kioti DK4710 SE HST CAB
I got weary of mounting that 350-pound giant octopus.
So I made a hangar. Just some welded up angle and a U bend of half-inch rod. I'll mount it on a post when I get the fencing up. For now, it's on a tree.
I'll make a little block and tackle from Alum and Acetel. That way it can sit out in the weather. It holds it off the ground. And is a snap to mount.
It soooOOooOOooOooOOooo Heavy look what it did to the tree.
   / Poat hole digger, Did Sumpin' #2
Dang, the title is very misleading. I thought you had a POTATO HOLE DIGGER instead. darn.
   / Poat hole digger, Did Sumpin' #3
You are only asking for heaps of troubles and possible injuries.
You need the goal post setup that works with the machine and not your back.
I did not invent this. Farmers down in TN have these. It was demonstrated to be the easiest method for on and off other than a fixture frame off a platform.
Moved to a new location. Ignore the drain pipe. LOL
   / Poat hole digger, Did Sumpin' #4
We have a come along hanging at the edge of a shed for ours.
   / Poat hole digger, Did Sumpin' #6
Sorry I'll go to work on that maybe next week.
Hmmm a machine to dig potato holes.
Should that be holes in the potatoes?
Nope not even close.
It's this...
About 100 years ago pulled by horses. A nice McCormick.
2011 Ford Ranger Ext. Cab Pickup Truck (A55852)
2011 Ford Ranger...
2017 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A55852)
2017 Freightliner...
UNUSED FUTURE (100) PIECES OF 12'X3' GALVALUME (A57193)
UNUSED FUTURE...
2015 Peterbilt 348 Dump Truck (A55973)
2015 Peterbilt 348...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
2012 BOBCAT E80 EXCAVATOR (A52707)
2012 BOBCAT E80...
