Weber kettle cold smoked cheese
/ Weber kettle cold smoked cheese #1
nickel plate
CA
2002 New Holland TC40S
It's coming to the end of proper smoked cheese weather in my location but I managed to get in one last smoke a couple of days ago. The 5:00 am temperature was thirty-four degrees, perfect for a two and a half hour cold smoke.
The key trick is to keep the interior kettle temperature under ninety degrees or your running the risk of melted cheese. The only heat generated comes from the "A-MAZE-N" smoke tube itself. I've heard of folks using trays of ice cubes or frozen water bottles to keep the temperature down but that seems a bit risky to me.
My favorite self-mixed blend is 75% apple and 25% cherry pellets which leaves a pleasant smokey flavor without overpowering the cheese's natural flavors. We've pretty much narrowed our favorites down to sharp cheddar and pepper jack varieties.
The last step in the process is to individually vacuum seal and label the 2"x3" blocks and refrigerate for at least two weeks which allows the smoke to further penetrate into the blocks. You can use ziplock bags but be sure to get as much air as possible out of the bag to avoid any long term molding.
Looks like I have enough of a "stash" to make it to the fall and the start of another smoked cheese season.
/ Weber kettle cold smoked cheese #2
Mmmmm. I can almost smell,taste it from here. Thanks for the post.
/ Weber kettle cold smoked cheese #3
Thanks for the posting. I am in the process of building a smoker out of a stainless steel 55 gallon drum. I lucked out on getting 2 SS drums. I will be using one of the smoke generators that use pellets like the one you are using. Maybe even the exact one. Where I live I will be able to get away with cold smoking for much of the year and besides making lox and cold smoking other meats I have really ben wanting to cold smoke cheeses. You have given me a little more inspiration.
Cheers,
Eric
/ Weber kettle cold smoked cheese #4
/ Weber kettle cold smoked cheese #5
I still have a Little Chief smoker in the shed, with the box. Their "cookbook" has directions to use the smoker and the box to cold smoke cheese.We done it a few times; comes out really good.
We followed the instructions on the last page of the Little Chief manual.
Thanks for posting that. I have a few Little Chief smokers and probably have a manual floating around but I have only ever used mine for smoking and drying meats. But lately I have been wanting to smoke some cheeses. Which kinds of cheese have you smoked? Chedar, Jack, Gouda, and so on? And what brand names? I don't think the brand will matter much but maybe, for example, Kraft sharp cheddar comes out better than Tillamook sharp cheddar. Though I don't usually buy those brands they are both fairly ubiquitous on the west coast and they could make a good benchmark.
Thanks Again,
Eric
/ Weber kettle cold smoked cheese #6
I think the most commercialize smoked cheese is "Gouda".
/ Weber kettle cold smoked cheese #7
Thanks Again,
Eric
We tried store brand (Safeway, Raley's), as well as Tillamook. Locally, Tillamook is one of the better higher grade brands, and the results were noticeable.
We've tried cheddars, swiss and gouda. Smoked sharp cheddar is pretty tasty.
Less smoke is better until you figure out what you like. A couple of the local ACE stores have had Jack Daniels whiskey barrel chips; gives nice flavor.
/ Weber kettle cold smoked cheese #8
Thanks for the reply. I'll try a good sharp cheddar and some gouda. I can hardly wait.
Eric
Possibly so but in my research, I found out that some commercialized various smoked cheeses sold in are local markets are not properly/traditionally cold smoked but are liquid/dipped in some sort of chemical. No thanks.
/ Weber kettle cold smoked cheese #10
Yep ^^^^ yuck.
I'm still pretty new (two years in, ten smokes) to cold smoking cheese so here are a couple of my "grasshopper" found observations:
I've smoked some of the supermarket offered Gruyere and Gouda brands and yes, they are delicious but also pricey (at least do it once for the taste experience) so I limit that smoke to family gatherings, holidays, special occasions when in smoke season etc.
Twice have smoked swiss and each time was disappointed in the flavor-don't know why, anyone else experience that?
I now stick to high end sharp cheddars and pepper jacks-our favorite basic choices, happy days!
Absolute low outside ambient temperature is the key to cold smoking and keeping the internal BBQ
temperature under 90 degrees for the duration.
If you vacuum or zip lock seal after the smoke, let the cheese rest and air dry especially if vac packed so the new fresh exterior smoked skin doesn't drain/suck/leach out of the block.
Enjoy!
Snap-On Zeus Diagnostic Machine (A63689)
Snap-On Zeus...
2015 MACK GRANITE (A65643)
2015 MACK GRANITE...
4x6 Utility Trailer (A62679)
4x6 Utility...
(3) Wheels and Tires for 4-Wheeler (A65579)
(3) Wheels and...
2022 BOBCAT T66 R-SERIES SKID STEER (A65053)
2022 BOBCAT T66...
Mini Universal Trailer Mover (A65640)
Mini Universal...
