3520 shuts off using PTO
/ 3520 shuts off using PTO #1
Policy Peddler
ford 1300
While mowing with my 3520 the the engine shuts off it will usually but not always start right up immediately, But not always. Then shuts off more often, after a shorter period of time, gets the point where it only run for a minute or 2 then will not start.
My thoughts are that iit is not the seat switch if it was it would not move after a period of time when I'm plowing snow as if you were off the seat.
Is there a relay somewhere that could be getting hot and shutting it off.
Any other ideas?
Thank you
/ 3520 shuts off using PTO #2
IRS Form 3520 is most often filed to report gifts over $100k from a foreign person.
A Form 3520 is filed separately from your tax return and like your return shouldn't be filled out while blowing snow or other chores. Operating snow blowers and filing IRS documents each require your full attention and should never be part of multi-tasking.
Speaking of full attention,now that you have mine,is there anything you would like to ask about your 1300 Ford tractor?😁
/ 3520 shuts off using PTO #3
Any other ideas?
Thank you
Is this a John Deere 3520? I would imagine there are a number of safety switches on this machine and you would have to go through the process of elimination to figure out if any of them are causing the trouble. Also carefully inspect the wiring for damage. Rodents can cause major problems and it often presents itself as intermittent.
Please be sure to offer as many details as possible otherwise it is very difficult for us to help you over the internet.
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
Soil-Max Gold Digger (A64126)
Soil-Max Gold...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
2017 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2017 FREIGHTLINER...
14in Digging Tooth Bucket Excavator Attachment (A64194)
14in Digging Tooth...
