Betstco FH-EFGC155 Flail, New Hammers But Problem With Cut.
   / Betstco FH-EFGC155 Flail, New Hammers But Problem With Cut. #1
wirlybird
Gold Member
Oklahoma
John Deere 3038 E, John Deere 3032E, John Deere 756, John Deere X585, John Deere 332
Ok, so I have replaced all of the hammers with new ones. I used the Titan 3.5" ones since they are about 3-4 bucks cheaper per hammer than Betstco ones and look good.
Tested on my test field which is about 5-6 inch grass. Overall the cut was ok, flail cut set at about 3 inches, but I discovered an issue. I know hammers are not the best for grasses!
On the non belt/drive side of the flail, right hand side as sitting on the tractor, it is leaving an uncut strip.
It is a little hard to see in the picture but the arrows try to show the strip the flail is leaving.
I made several passes and the strip is there on all passes. it is consistent also.
Went back to the garage and inspected under the flail. Nothing out of the ordinary. Hammers all on correctly.
I cut this same field with my JD flail and it does a great job. It uses the scoop style blades so it is a bit different but no strips or other odd stuff.
Thanks for any ideas or things to check out. I just don't know why it leaves this strip on one side. The rest of the width of each pass is pretty good.
   / Betstco FH-EFGC155 Flail, New Hammers But Problem With Cut. #2
need a pic of the action side.
   / Betstco FH-EFGC155 Flail, New Hammers But Problem With Cut. #4
where the hammers are
   / Betstco FH-EFGC155 Flail, New Hammers But Problem With Cut. #5
Is one of the hammers on backwards?
I noticed with mine this year where I make only one pass, there are two strips, where the tires lay down the grass and it doesn't get cut.
My first thought was I put a hammer on backwards but that's not it.
   / Betstco FH-EFGC155 Flail, New Hammers But Problem With Cut. #8
   / Betstco FH-EFGC155 Flail, New Hammers But Problem With Cut. #10
Maybe one or 2 of the hammers are not swinging freely. Check you didn't over tighten them and that they all swing smoothly. You probably thought of that but throwing it out there in case.
Good suggestion and a real possibility. I did check and these do have some room laterally on the mount.
I did check for free swing though. Thanks!
   / Betstco FH-EFGC155 Flail, New Hammers But Problem With Cut. #12
I’m having a similar issue with some winter weeds or grasses that haven’t died off yet. For me it’s the tires pressing down the grass. It should be much better with the Bahai grass coming back now.
I just finished today replacing all the Y blades. I sure hope I’m not disappointed as it wasn’t an easy job. Flail Master was good to work with.
Update: I am pretty convinced at this point that the tires are causing the initial problem.
I think this being a flail that spins against the direction of travel doesn't help with this issue. I think if the grass is partially laying over and pointing in the direction of travel then the blades may have a harder time cutting and may more just push the grass down.
Anyone come up with any ideas to help combat this issue?
I can see that the flail does create some suction but it isn't much which I think is just the nature of the mower.
   / Betstco FH-EFGC155 Flail, New Hammers But Problem With Cut. #14
I’m ready to agree with you on the tire tracks. I just replaced all my Y blades and still have tire tracks. It’s better but still an issue. Blame it physics I guess. I’ll toy with the roller height to see if a shorter cut creates more suction. I expect it does.
I have dropped my cut from 3 inches to 2.5 and it didn't make much difference. Much lower and I'll hit the ground. Going slower seemed to help a little but really it is at a crawl so that is not efficient!
I think wet, green grasses are part of the issue as they don't really spring back up much.
I can see at the front of the mower that it is trying to "lift" the grasses some.
Does your flail spin the same as tire movement or spin against it? Mine rotates in the opposite direction of the tires forward movement.
My big John Deere one spins forward, same as tire rotation, and doesn't have this issue. However it is using the scoop style cutters rather than hammers.
   / Betstco FH-EFGC155 Flail, New Hammers But Problem With Cut. #16
Mine goes opposite the tire rotation, sweeping forward. I have come to prefer it in tamed areas over the rotary cutter. No windrows mostly, but also shorter, requires less power, & quieter.
   / Betstco FH-EFGC155 Flail, New Hammers But Problem With Cut. #17
Yep, cut it lower.
Went out and did a 3.5 acre field. Nice an flat with 5-8 inch natural field grasses and weeds. Pretty tame stuff.
Ran at a 2.5 inch cut and took my time.
Then end result is terrible. Looks like it was done with a crappy, unleveled brush hog with bad blades.
You get one nicer strip of cut grass but then you also get strips of grass that is 3 inches taller.
It is really disappointing.
If it didn't leave these stripes it would be a really nice cut.
I don't think there is anything you can do about it.
   / Betstco FH-EFGC155 Flail, New Hammers But Problem With Cut. #19
Strange, I don't get that kind of cut. Maybe grass is too wet?
I have mine offset and do overlapped cuts in 2 directions, maybe try that?
I tried overlapping enough to hit the strip left from the last pass but by doing that I loose almost 2 feet of cut. It still didn't do a great job recutting but more is the issue of loosing so much width for each cut.
I appreciate the suggestion.
Once the rain stops and things dry a bit I am going to take my big JD flail across the stree to my field and do a few passes then a few with the Betstco and see how they compare under the same conditions. May even take my little 917L out and try it.
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
2021 CATERPILLAR 299D3 SKID STEER (A60429)
2021 CATERPILLAR...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2017 FREIGHTLINER...
2023 Chevrolet 1500 Silverado Z71 Crew Cab Pick-Up Truck (A59230)
2023 Chevrolet...
2018 Yamaha VX1050B-TA Waverunner Jet Ski (A59231)
2018 Yamaha...
