What is the dumbest thing you have done with your equipment ?
   / What is the dumbest thing you have done with your equipment ? #101
Or replacing a fusible link with heavier gauge wire and not trouble shooting why it blew in the first place. It fried the entire lower harness on my L2850. had to get a custom built harness.$$$
   / What is the dumbest thing you have done with your equipment ? #102
Using my equipments tracks or tires as a portable workbench. That was a speed square like top of pic in it's better days.
I always thought that speed squares came in two pieces... at least mine always look like the one in your picture.
   / What is the dumbest thing you have done with your equipment ? #103
Just saw this driving down my road this morning at a neighbors house - as I drove towards it, saw what looked like a utility truck working on some wires
Turned out to be a pick up truck pulling a trailer with a tractor with a backhoe on it. The "elbow" of the boom and stick had snagged and pulled out low hanging wires (not the power line at the top though)
Didn't look like anything broke, but the wires were definitely stretched. If they just untangled them from the backhoe, looks like the wires would be about six feet off the ground.
Going to be an expensive morning for someone....,
   / What is the dumbest thing you have done with your equipment ? #104
Not me I think some of the bigger ones are 2 piece, you call it a rafter square? Anyways its in several pieces these days sitting in the scrap bin. 😂
   / What is the dumbest thing you have done with your equipment ? #105
When I was working part time as a boat mechanic one of our pet saying was "If you can't find out why the fuse is blowing put a prop pin in it and look for smoke,"
   / What is the dumbest thing you have done with your equipment ? #106
We had a similar saying in the military. "Replace the fuse with a nail and follow the burned wiring back to the faulty component."
Doug in SW IA
   / What is the dumbest thing you have done with your equipment ? #107
Doug in SW IA
The problem for me occured when the fried wire continued to fry the rest of the wires bundled in the harness.
   / What is the dumbest thing you have done with your equipment ? #108
A few weeks ago I noticed a leak in the RV in my infinite wisdom I improperly drained the water heater. Did you know you can buy 2 residential ones for the price of a single 6 gallon motorhome one?
Sometimes one never learns from their mistakes. This one did not turn out bad but could have; I should have used the bigger truck. BTW theses are walnut I found on the farm, they were dead before I cut them.
2019 Freightliner M2 106 8.5 CuYd Street Sweeper Truck (A53422)
2019 Freightliner...
John Deere Z994R (A56469)
John Deere Z994R...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2015 Peterbilt 320...
ST205/75R15 Trailer Tires (A55788)
ST205/75R15...
2012 Ford E-250 Cargo Van (A55852)
2012 Ford E-250...
UNUSED FUTURE 29" PALLET FORKS W/ MAST (A57193)
UNUSED FUTURE 29"...
