2012 JD 4320 FEL Issues
/ 2012 JD 4320 FEL Issues #1
griff1957
Member
2003 NH TC35
Was working on a burn pile yesterday when I popped a hose on my grapple, not a major gusher but a pin hole. Worked on the pile a little longer with the grapple working properly but noticed the fel bucket was not going all the way up. Parked it and checked hydraulic fluid level this morning and it was about a 1.5 gallons low, topped it off but fel still not going up all the way. Is it possible the raise/lower cylinders got air locked? Any suggestions appreciated in advance. Thanks
/ 2012 JD 4320 FEL Issues #2
It is possible and the way to get rid of air in the cylinders is to just fully cycle the cylinder a few times. That should purge the air.
I tried that several times but no help. I ran across another posting with a similar problem that mentioned it could possibly be the quick disconnect fittings, the fellow stated that he just disconnected and reconnected which solved the problem. I’ll try that this evening.
/ 2012 JD 4320 FEL Issues #4
That is a good suggestion. They can sometimes be a bit of a problem. Is the hose on the grapple still leaking?
Had 2 new ones made up today at a cost of $175…will install them this afternoon and check the QD connectors.
Well I would have never believed it, usually things like this cost me hundreds of dollars. Got the hoses replaced and then checked my QD couplers, found one going to my fel cylinder popped lose, it appeared to be fully connected by just looking at but it wasn’t, a limb or stick must of have hit it. Reconnected and fel worked…go figure!!!!!
/ 2012 JD 4320 FEL Issues #7
Glad to hear you got it all sorted!! And thanks for letting us know how it turned out and your solution to the problem!!
2018 Ford E-450 Shuttle Bus (A61573)
2018 Ford E-450...
1991 Yamaha 130hp 2-Stroke Outboard Boat Motor (A66738)
1991 Yamaha 130hp...
2025 TEXAS PRIDE 14FT T/A DUMP TRAILER (A59914)
2025 TEXAS PRIDE...
Baby Goat Decorative Statue (A66738)
Baby Goat...
2011 FORD F-550 SUPER DUTY (A67714)
2011 FORD F-550...
2009 CHEVROLET SILVERADO 3500 TOW TRUCK (A65057)
2009 CHEVROLET...
