Stabilizer spacing won’t fit my old attachments
   / Stabilizer spacing won’t fit my old attachments #1
Dustypp
4707 Massey
Hello recently upgraded to a bigger utility tractor from a smaller ford 7209 and the issue is the stabilizer spacing for bottom implement pins. the stabilizers won’t come in enough to hook both pins in the ball bearings and wondered what the solution was for that is there was one instead of having to buy all new attachments. Any help is appreciated thanks
   / Stabilizer spacing won’t fit my old attachments #2
For me it would be to drag each implement into shop and fabricate/modify each to fit new tractors dimensions.... The cost of a days labor and materials for fabrication would probable be a lot less then replacing implements and the having to leave old implements littering property or trying to find a buyer to make them go away....
Looking at picture you supplied I think I would get a CAT "X" (CAT 1-2-3) drawbar that fits your tractor and just bolt or weld implement to drawbar
Great idea, would rather not have to buy all new. don’t think longer hitch pins on each end of implement would do the job? Too much stress on pin?
   / Stabilizer spacing won’t fit my old attachments #4
Did you go from a cat I 3ph to a cat II?
The spacing is different for the pins. 26" vs 32"
It also looks like your bale spear is a homemade spear that isnt even 26" cat I dimensions.
Have no idea what a 7209 ford is. Never heard of it. And you list a 5075e in your profile.....which is a deere model number but dont look like a deere in the pic.
What was the old tractor?
What is the new tractor?
What is the current spacing between the pins on that spear?
   / Stabilizer spacing won’t fit my old attachments #6
If you unpin both stabilizers will the lower arms swing in close enough then?
   / Stabilizer spacing won’t fit my old attachments #7
Or as has been mention modify the bale spear to cat 2 sizing, saw off the end plates add on more square tubing and reinstall
the end plates with cat 2 pins.
   / Stabilizer spacing won’t fit my old attachments #8
Info on the Massey 4707
MF 4700
Old ford the 7209 was loader for it. I didn’t get a 5075 too liteweight, I have a Massey 4707. May be homemade but it fit the smaller ford just fine. The tractor I have now is a 75 horse
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
TRANSMISSION JACK & TRACTOR CYLINDER (A54757)
TRANSMISSION JACK...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
KUBOTA KX057-5 EXCAVATOR (A52707)
KUBOTA KX057-5...
2007 Club Car DS Gas Cart (A55853)
2007 Club Car DS...
