Wood chips and composting
/ Wood chips and composting #1
Garandman
Elite Member
Mount Sunapee NH / Dorchester, MA
Kubota L3200 HST
Cut down some trees for firewood, and going to run the tops through the chipper. So I’ll have bucketloads.
Can this be used to compost?
If so what else should I add?
Can I just dump it in a pile or do I need to contain it?
TIA.
/ Wood chips and composting #2
They'll take forever to rot down in a compost pile. I use 'em for mulch, or if you have an embankment that tends to wash out, they'll help hold the soil.
/ Wood chips and composting #3
It will not turn into compost quickly. If you have lots of it and leave it in a pile, it will begin to heat up, especially if you are chipping live green material. Urban arborists often have big piles that they continually feed, piling with tractor or bobcat. That stuff cooks down at the bottom and makes real good mulch for new and existing plantings.
Wood chips differ in compostion. If you are chipping tree, bark, leaves and needles, it will begin cooking quicker. Forty miles from me General electric is mixing all sorts of wood chips and cow manure to generate power.
/ Wood chips and composting #4
TIA.
I just dump mine in a pile, underneath a red cedar tree. It's also just uphill slightly from where water drain from the front lawn. That keeps it from getting too wet.
I collect kitchen non meat stuff and eventually fill an old garbage can. Then I level the compost pile and dump the garbage can and then repile the pile. In putting the kitchen stuff in, if a lot, I scoop some mulchy material from the top of the compost/mulch pile and put it on the kitchen material I just put into the garbage can.
Makes compost in around 6-9 months.
Top tree greenery plus chips will make it cook pretty readily.
Been doing mine since 2000. Used to get a lot of leaves and chopped them up to add to it, but my leaf source dried up. Getting lots of wood chips with some tree top material and that kitchen stuff.
/ Wood chips and composting #5
I chip and shred just about all woody material around my place. (MacKissick TPH185) 'Anything smaller than what is useful for the wood stove .
I've had my share of piles, and have three five foot tall piles "composting" now. I've had a few rather large piles over the years.
Compost quickly is not in the cards, but what's the hurry? I like about three years to break down and turn black. Chips need a lot of nitrogen. Let them get the N2 from the air, not the soil. They are not a good choice to put into the garden soil, but GREAT to put on top of the garden soil as moisture retaining mulch. Weed control is a great benefit as well. The chips will break down at the soil interface without depleting soil Nitrogen. I've gone over 6 inches thick on garden walkways.
If you are in a hurry, Turn the piles every week or so. I use the FEL to do this. I can't say there is a real "turning" with my way. More like "churning" ;-). I just scoop up through the pile and create a new pile about five feet from the old pile.
I year (summer and winter) and the material is good for direct application to any garden soil.
I also have a soil screen that I set up when the wife want's some "very nice material" for beds etc. The sticks etc. get run through the shredder again.
If the pile doesn't get too hot, it can get quite a population of earth worms ;-)
/ Wood chips and composting #6
I use them to bed pigs for a year, move the pigs and pile everything for a year, then till in the garden. It’s still very identifiable as wood chips but my soil is so bad at least it helps retain some moisture. I bet the third year would probably be about right if I added more green material and turned it at the end of year two instead of putting it in the garden.
/ Wood chips and composting #7
Garandman, you didn't say what kind of trees, or what you'd use the compost on. In the off-chance they're Black Walnut (or even Hickory or Butternut), be aware that the wood and bark chips will contain juglone. The resulting compost could actually ****** whatever you plan to grow. Here's a link. How to Stop Black Walnut Juglone Toxicity | Gardener’s Path.
/ Wood chips and composting #8
I looked into that when I cut down a 40 foot Black Walnut . The trunk logs are still out back on sleepers ;-)
The Harmful stuff breaks down in less than a year ..."by some accounts" .
I did let the chipped and shredded top branches set a year, then just mixed it in.
The solution to pollution is dilution!
/ Wood chips and composting #9
I use the chips to line my trail entrance/exits.
Doing thinner layers also seems to break them down faster.
I have a few piles from last fall I need to move. We'll see what the bottom looks like when I move the chips out.
Breakdown is fast as this is mostly Ash.
Have had Cedar and some other trees which seem to last forever on the ground.
/ Wood chips and composting #10
Organic gardeners have had problems with using pig manure in gardens, as it may carry trichinosis. If you do plan to use it on your garden get it good and hot while composting, then wash the vegetables well before. I have a 1/4 yard soil sterilizer which my father used in the greenhouse, and cook it at 160' F; yet I still won't use it for root vegetables.
Supposedly freezing will also kill roundworms.
I had a 2 acre field reclaimed in 2009, and ended up with about a dozen stump piles scattered throughout the field. About 2 years ago I finally bought a grapple and set out to pull the stumps out of the pile, only to discover that they had rotted nearly away. You may not have 10 years to wait but chips should rot a lot faster, especially if mixed with other materials.
/ Wood chips and composting #11
One thing I might add. If you are using your chips for bedding to mix with manure, make sure you know your chip source. Some wood is TOXIC to some livestock. You can look up something like " black walnut or black locust toxicity to animals"
/ Wood chips and composting #12
Cedar can also be noxious to lungs as well as a carcinogen... including in humans.
/ Wood chips and composting #13
anything that will go thru my 16" Vermeer and gets chipped goes in the dirt to rot. If you leave it on top it takes longer but will work.---spread it med. thickness, plow under 18" deep and good to go! Mixing green material and manures does wonders to speed up the process.
I add a lot of commercial fertilizers to it as well to offset the N lock that they claim happens with wood chips. I still dont believe it but i am no chemist! lol!
/ Wood chips and composting #14
Commercial fertilizers, most of them, are salt-based chemicals that kill everything in the soil. Better to collect your urine and use it. It's 18% nitrogen.
/ Wood chips and composting #15
I keep hearing that. Yet my soil was so stagnant that I never saw an earthworm for the first 15 years that I worked it, so I had to do something to make things grow... and that was before I had the entire 2 acres stumped, taking the first 6 inches of topsoil with it. Miracle Grow was my friend for years. I am just starting to see worms now, and I put in my first garden here in 2002.
/ Wood chips and composting #16
worms, toads, frogs, unknown bugs,--you name it I got it in my high fertilized 4.5 acre garden! Always have had them and the wood chips and compost dont seam to hurt anything.
/ Wood chips and composting #17
Me wonders how much nitogen is in 5 gallons of human urine....even though that's a lot of pee to collect...? Yet I don't mind releiveing myself in the garden now and then. :rolleyes:
/ Wood chips and composting #18
I've noticed that if I take a whizz on the lawn, the grass turns a very deep, almost blue-ish green color a few weeks later.
Great deer deterrent around my wife's flower gardens too!
/ Wood chips and composting #19
Urine typically contains 18% nitrogen. Needs diluting normally to be used on plants.
/ Wood chips and composting #20
Are you using a chipper or shredder to produce compost? If your using a chipper, which make and model.
I want to make compost but my Wallenstein 4" gravity chipper produces very large chips that will likely take years to break down enough to use as compost. It also produces a lot of small twigs and a lot of the small branches (with needles) get spit out whole. I have tried spreading the chipped material out and running over it with the brush hog and that certainly makes the chips a LOT smaller but it involves too much time and effort. I would prefer a once and done approach.
New Holland 216 Rake (A63688)
New Holland 216...
New/Unused ATS Plasma Cutter (A65583)
New/Unused ATS...
2022 Ford Explorer AWD SUV (A61574)
2022 Ford Explorer...
F-250 Super Duty 4WD 6.2 (A63688)
F-250 Super Duty...
Lockers (A62613)
Lockers (A62613)
PT 6' Dirt Pan (A64127)
PT 6' Dirt Pan...
