Cool Or Creepy Things Found In The Bush Or On Your Property
/ Cool Or Creepy Things Found In The Bush Or On Your Property #221
There was a low spot in our lawn between my garage and my neighbor's garage. I'd add some dirt to it every year and it would sink further. One day, my neighbor told me that there was an old septic tank there, that was fed by my house well before I bought it. Only used for the kitchen now. He said there was a fire in the woods behind the houses, the fire dept. came through with a truck and crushed the tank. He suspected the tank was still collapsing. So I wanted to see to make sure. I started digging in the low spot and found a large toy doll stroller and a suitcase about a foot under the grass. The suitcase is what had been collapsing over the years. I opened it up and inside were a bunch of empty plastic ketchup bottles.
That's all I have to report. The septic tank was concrete and solid as a rock. Don't know what the fire department collapsed, but it wasn't that.
/ Cool Or Creepy Things Found In The Bush Or On Your Property #223
There was a low spot ...I started digging in the low spot and found a large toy doll stroller and a suitcase about a foot under the grass. I opened it up and inside were a bunch of empty plastic ketchup bottles.
/ Cool Or Creepy Things Found In The Bush Or On Your Property #227
/ Cool Or Creepy Things Found In The Bush Or On Your Property #228
Chevrolet should bring back the Apache. That was a classy truck.
If any manufactures would just offer a manual trans, no power windows/mirrors/anything, I'd be happy. Just need 4WD, a radio, and turn signals get all the other crap off my truck because I don't want to pay for it.
/ Cool Or Creepy Things Found In The Bush Or On Your Property #229
:unsure: is right. I was expecting something horrible. You dig in the dirt, find a stroller that would hold a large doll next to a suitcase... Yikes! I really didn't want to open that suitcase, but did.
/ Cool Or Creepy Things Found In The Bush Or On Your Property #230
My Grandfather, being a Country Doctor, had a habit of buying out widow's estates as "House and Contents." House and contents, means you buy the entire estate if no one else wants to challenge it with the single check, to be bought out. i always thought this was difficult for me, cause I'd have to sort though the good and bad. And the Grandfather wanted to keep everything..... for some reason.
Well, one House and Contents turned out to be strange. While looking at one of his new purchases, I noticed a trap door in the kitchen no one had seen before. This was an old house and it was common to have a root cellar close to the kitchen.
I pulled up the trap door and it was filled with clothing. New, old, clothing, with the sales tags still on them.
So I started to take the clothes out, and found a step! And then another step, and another, and another.
All filled up with rotting, new, old clothing that still had tags on them. And then I saw the rafters, meaning that this as an entire basement. I ordered a dumpster to the site. Then spent an entire week doing nothing but pulling out what must have been 250 thousand dollars of, now rotted, and useless clothing, that had been neatly stacked in the basement. All of them still had sales tags. It took three dumpsters. One of the House and Contents was a 1980 CHEVROLET EL CAMINO. I didn't like it, so turned it down. I was just happy Grand Pa was paying for my college tuition. :)
/ Cool Or Creepy Things Found In The Bush Or On Your Property #232
/ Cool Or Creepy Things Found In The Bush Or On Your Property #233
I miss monotype and linotype. I always though that there was something magical about the pool of molten lead being turned into lead slugs. Many newspapers were still using individual movable type until well after men had walked on the moon, just like Gutenberg used in the 15th century. Some things change slowly.
I remember seeing one model for casting something like Monoblock in a bookbinding plant that had a very odd five finger "Keyboard". No idea what it was called.
All the best,
Peter
/ Cool Or Creepy Things Found In The Bush Or On Your Property #234
At one garage sale, i found a real human skull with a black candle on top of it. The proprietor of the garage sale was a bit embarrassed, and said this was not for sale.. :)
/ Cool Or Creepy Things Found In The Bush Or On Your Property #235
All the best,
Peter
Linotype had close to 100 keys.
Never saw a Monoblock.
The first week I started at the newspaper in 1987, I was assigned to help a contractor convert the saddles on the last press unit from lead plates to polymer coated aluminum printing plates. It was a keyed letterpress type printing press. The lead plates were around 1/2" thick. This company machined steel saddles that were the thickness of the lead plates minus the thickness of the aluminum plates. They had spring loaded lockups to hold the new plates. We'd set a saddle template on the press, lock it up like a lead plate, then use a mag drill to drill a bunch of mounting holes to hold the new saddles in place. Then remove the template, tap the holes, and then install the new steel saddles. It was the first time I'd ever seen a printing press, a mag drill, and a tap. It took two weeks to convert that last unit. We had to work while the press was running, so there were paper webs sailing over us for hours at a time. Maybe a foot or two above your head. And it was LOUD in there.
I loved it! Best job I ever had. Lasted 30 years. Still miss it, but life goes on. ;)
/ Cool Or Creepy Things Found In The Bush Or On Your Property #236
Nerves. Of. Steel.
I have seen those presses in action, and know the tolerances. Not human compatible. 😱 Sounds like a great start to a great job though.
I had a quick look for the type casting machine that I saw at the Acme bookbinding plant outside of Cleveland. I can't find it in any of the common histories of typesetting. No idea which kind it was...
All the best, Peter
/ Cool Or Creepy Things Found In The Bush Or On Your Property #238
Nerves. Of. Steel.
All the best, Peter
After that project was over, we had to convert all of the press units from keyed to keyless. Some of that involved sitting inside of running press units while mounting electrical boxes, wiring harnesses, then making adjustments to the new sensors. You haven't lived until you climb inside a running press unit. It sounds like you're sitting inside the engine compartment of a large truck doing 60. The rollers are inches from your head. One wrong move and it would be like putting your head into a giant wringer washing machine. Death would be instant. No loose clothing. No rags in pockets. All shirts tucked in. And I cut my hair pretty short, too. I ranked that part of the job right up there with jump-starting aircraft that had the plug between the prop and the leading edge of the wing. Total concentration or death. 😬
/ Cool Or Creepy Things Found In The Bush Or On Your Property #240
When we bought our 25 acre rental property, there was indeed a dump on it. Spent years getting rid of all the stuff, including huge amount of old metal roofing. Still finding stuff today.
The property is one of the original properties on the lake, and was an old lodge once owned by a gold refining company. Never found any gold, however!
However, there is still one underground chamber that looks like a collapsed root cellar that we haven’t yet explored…
Greenworks Commercial 82V Utility Vehicle 500 CAMO Model: U500SC - DEMO UNIT (A63689)
Greenworks...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
John Deere 348 Square Baler (A65579)
John Deere 348...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
2016 Etnyre Falcon Live Bottom Trailer (A62613)
2016 Etnyre Falcon...
