What are the most reliable tractors to own?
   / What are the most reliable tractors to own? #101
Well, I look for the ones that stuff doesn't happen to, and constant rebuilds and service... as you can find them...but have to check long and hard to find them...and do careful research and check over stats and comparisons..
Good luck with that mind set.Trust me there is NO perfect tractors on the market.Same with vehicles ..
   / What are the most reliable tractors to own? #102
Well, dealer locale and parts do’t matter much to me, as my ‘09 Kubota BX25 has never broken down. But I suppose it’s good to know I have them there if needed!
(Actually I did have to go to the dealer once - to put on the rear snowblower I bought from them. Went smoothly.)
   / What are the most reliable tractors to own? #104
Yes, but there are those that you dont have to rebuild FIVE times like I did on my VEGA, not a broken fan belt or so and thats what you want to acquire...
And here again we see a pattern as we have Kubota and John Deere and surprisingly Mahindra as "3 brands that show up on virtually every ‘best’ list out there for tractors. " The 3 Most Reliable Tractor Brands
   / What are the most reliable tractors to own? #107
Only takes me 1 time to put my hand in a fire and get burnt to figure out I did not like it.Good luck on your choices ..
   / What are the most reliable tractors to own? #108
Uh-oh. You must be new to this.
Take it from somebody who has been using tractors for over 60 years: those of us with a little experience under our belts know better than to make a fate-tempting statement like that, regardless of the brand/model.
So why did you buy a Kioti....
   / What are the most reliable tractors to own? #110
Not sure what you have against Kioti ?
My previous tractor was a JD 850.
I've owned my Kioti DK 35 for 22 years.
Its every bit as well built as my JD was. Its been every bit as solid and reliable.
Honda EU3000is Gasoline Companion Inverter Generators (A54811)
Honda EU3000is...
2025 Star EV Capella Low Speed Electric Cart (A55853)
2025 Star EV...
2013 MACK CHU613 DAYCAB (A55745)
2013 MACK CHU613...
(28) 4' FLOURESENT LIGHT CEILING FIXTURES (A54757)
(28) 4' FLOURESENT...
2008 CAT D6T DOZER (A55745)
2008 CAT D6T DOZER...
