Would a zero turn be faster than a B2601?
   / Would a zero turn be faster than a B2601?
Yes a ZT with the same size 60" deck will mow your lawn a little faster. Also get stuck much easier. Also rotten on rough or steep ground. Mowing yours in 1.5 hrs is quite good really. Unlikely worth a big investment to improve on it.
That is what i am thinking after all a Z400 is $6000 plus.
I think i save some time by not backing up at all so i am constantly going forward mowing grass.
I have a few trees and i can't go under them the rops catches even when down. I think a zero turn would have the same issue.
  • Good Post
Reactions: JWR
   / Would a zero turn be faster than a B2601? #22
I went from 3 hours for a 3 acre lawn with a 48" rider to 1 hour with the 60" zero turn and my trimmer work went from an hour to 15 minutes. BUT, I went from mowing once a week to mowing twice a week, since it looks so good and it's no longer a major pita. The zero turn is not really work, seat time is fun.
   / Would a zero turn be faster than a B2601? #23
1 hour 20 minutes with your current setup for 3 acres isn't bad.
I doubt you will save more than 15 minutes with a 60" zero turn.
   / Would a zero turn be faster than a B2601? #24
A friend has a long retaining wall that's about 10-12' deep. Somehow, he managed to run off it with his riding mower and didn't get badly hurt. A ZTR can turn a lot quicker and isn't something I would recommend to him or anyone where a little nudge of the controls can end up in a disaster.
Would also say that turf tires on a ZTR can be problematic for sliding on a hill. So might want to spec other tires if hills are involved and buying a new machine.
But....if the terrain is essentially an old, rough field that's now become a yard free of many obstacles, then the B2601 may just be perfectly fine for tackling that job.
A lot of this really depends on the terrain.
   / Would a zero turn be faster than a B2601? #26
Why not add a towable gang mower. An 8' one would probably cut down the time. My uncle used one years ago on his 5 acres. Should be a lot less than buying a $6000 mower.
   / Would a zero turn be faster than a B2601? #27
Zero turn ROPS usually fold down about 45*. Helps TREEmendously under trees.
I know a lot of TBN’ers like their 4WD CUTs but when you mount a mower on any of them, it diminishes their ability to be used for digging or going into the woods.
Instead of buying a new CUT with a MMM or rear finish mower, buy a slightly used CUT (maybe even one without a DPF?) and put the savings towards a tough zero turn. Not much difference in cost.
Besides, more fun & useful to own those 2 pieces of equipment, than one with a mower hanging off it. ;)
   / Would a zero turn be faster than a B2601? #28
Yep!
Went under a low hanging branch a few years ago...WOW!! Almost flipped the mower over assbackwards!!
   / Would a zero turn be faster than a B2601? #30
A ZTR will mow a lot faster than a tractor. You’ll probably want to throw away the turf tires and mount something more aggressive though.
Deere 35P (A53317)
Deere 35P (A53317)
2013 Husqvarna LGT2654 54in Riding Mower (A55853)
2013 Husqvarna...
Great Plains 2000 20' Grain Drill (A53317)
Great Plains 2000...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
Sterling AT (A55301)
