What tractor or piece of equipment for this hilly pasture?
   / What tractor or piece of equipment for this hilly pasture? #1
ShowroomShine
Gold Member
Raleigh NC
2019 Case IH 55A
Wife and I are buying a second home in Virginia to vacation at and do short term rental. This particular one has a 13 ac pasture which has been used very recently, but is extremely hilly in spots. We won’t keep animals on it since we won’t be here all the time, maybe rent it to a local farmer.
I’d like to see what piece of equipment would be the safest to mow and help maintain the property? I want something I can leave here so I don’t have to trailer my BX or larger Case IH back and forth when I go up. Budget of $5-7k max. I don’t have any illusions that I will be mowing the very steep parts, but I’d like to feel somewhat safe mowing the other areas that are less hilly.
I feel like a normal 2wd tractor like a MF 135, IH 444 etc would fit the bill just fine but still can be tippy. Thought about another BX for low center of gravity, but I know the capability is limited.
What are your suggestions?
   / What tractor or piece of equipment for this hilly pasture? #2
Here is a well developed thread on your topic from the T-B-N ARCHIVE:
   / What tractor or piece of equipment for this hilly pasture? #3
2 wheel drive would be fine if it’s dry. I can’t imagine brush hogging that with a BX, just to small. I’d want at least a 5 foot brush hog and a 6 would be better.
That thread looks more about the roughness of a pasture not the severe slope like I’m asking about.
   / What tractor or piece of equipment for this hilly pasture? #5
Those slopes are not severe. Go up/down, or angle wise. Any wide front and brush hog type mower…...
   / What tractor or piece of equipment for this hilly pasture? #6
Those slopes don't look all that steep to me. Here's the one I mow twice a year:
I have mowed it crossways, but now mow it up and down the slope, with a 4wd John Deere 870. It is a bit of a load going up with a flail, was less so when I used a rotary cutter.
   / What tractor or piece of equipment for this hilly pasture? #8
This^
OP, how many acres do you want to mow and how much time do you want to spend? I don’t think they are anywhere near justifying any kind of specialty machine, just about any properly operated and ballasted tractor should be able to mow that. A 135 with wide stance tires and axles would be no problem, front weights would help.
The pictures may be a little deceiving but the areas with the taller brown grass you would have a hard time walking down.
  • Good Post
Reactions: JWR
   / What tractor or piece of equipment for this hilly pasture? #10
Have you tried to measure the slope? The one I showed above measures 21 degrees in the steepest parts, according to my iPhone. Yes, I have difficulty walking down it, more so since I turned 80, but it was never easy.
2024 CATERPILLAR 289D3 SKID STEER (A52705)
2024 CATERPILLAR...
BENNU HYD SCAFFOLDING SYSTEM (A52706)
BENNU HYD...
(48) 1" X 2" X 87" TUBING (A54756)
(48) 1" X 2" X 87"...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55302)
2022 John Deere...
2018 JLG 4045R 40ft Electric Scissor Lift (A55787)
2018 JLG 4045R...
2013 East Manufacturing 45ft T/A Walking Floor Trailer (A55788)
2013 East...
