Stellantis replacing hemi with 3.0L I-6 engines?
Status
Not open for further replies.
   / Stellantis replacing hemi with 3.0L I-6 engines? #81
So my old SD would only benefit from an 8spd in fuel efficiency?
Yup pretty much.
Your old 4 speed (I owned plenty E4OD and 4R100 transmissions and they were awful) only locked up in 4th gear. First couple are slush. The new transmissions have more gears and lock up in more of them. That creates more efficiency and better fuel mileage. You will get better performance in that the ratios between gears are improved. Instead of sitting in one gear through a longer RPM range, the engine moves to another gear, staying at optimal RPM.
The main reason for more gears is fuel efficiency, better performance is a side benefit.
   / Stellantis replacing hemi with 3.0L I-6 engines? #82
Yup pretty much.
And you have that exactly backwards.
  • Good Post
Reactions: LD1
   / Stellantis replacing hemi with 3.0L I-6 engines? #83
torque is a function of bore x stroke...not cylinder configuration. Inline motors usually have a longer stroke, which gives them an advantage in torque. However a long stoke is bad for RPM's So it's always a trade off.
In line six also lasts longer because their crank has more bearing support than a V-8. Lower RPMs results in less wear & better longevity.
   / Stellantis replacing hemi with 3.0L I-6 engines? #84
Yup pretty much.
The more it locks up the more heat it creates and heat robs power.
New trannies have better torque management and allow for closer gear spacing. It makes it more efficient by not having to wrap out an engine to shift gears.
   / Stellantis replacing hemi with 3.0L I-6 engines? #85
I know plenty of diesel engines in a V that have huge bed plates to support the crank. That is not the reason.
Inline diesels are simple and cheap to manufacture...which has been and always will be the biggest advantage over a V engine.
   / Stellantis replacing hemi with 3.0L I-6 engines? #86
Taken from source below:
“For example, automatic transmissions used to only have three to four speeds. Now, you can get automatic transmission vehicles with up to eight gears. That said, having more gears means there’s no need for the vehicle engine to revolve higher during each shift. That alone, it makes automatic cars more efficient than they already were.”
Source: Do Automatic Cars Use More Fuel Than Manual? | Carketa
   / Stellantis replacing hemi with 3.0L I-6 engines? #87
Yep, theres gazillions of V-8’s in those expensive high end PACCAR trucks, isn't there?
V-8s are toast. They are inefficient and expensive. They dont run as long and they have more moving parts. Still a good engine for racing though.
Thats why V-8s are disappearing in favor of in-line six configurations.
   / Stellantis replacing hemi with 3.0L I-6 engines? #88
You just made my case. Thanks.
   / Stellantis replacing hemi with 3.0L I-6 engines? #89
If the V8 was simpler and cheaper to make, they would be. But as always you argue in absolutes and come back to the stellar example way too much.
   / Stellantis replacing hemi with 3.0L I-6 engines? #90
The package is more compact, meaning they have broader appeal to a wider range of vehicles.
Status
HARD TOP FOR CONVERTABLE CAR (A58374)
HARD TOP FOR...
MASSAGE CHAIR (A58214)
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
2012 Western Star Trucks 4900 SA Truck, VIN # 5KJJALDV0CPBE2239 (A57453)
2012 Western Star...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
2013 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2013 Freightliner...
