Should I use conventional oil, or synthetic oil in my tractor.
   / Should I use conventional oil, or synthetic oil in my tractor. #71
Being a preferred customer, i get it for $8.70 cheaper than retail. That is $37.79 per jug. A jug of T6 $5w40 is $59.99.
Amsoil for me, far better oil at a better price.
I’m buying what Cummins recommends for my truck motor: Valvoline synthetic for $30/gallon. It’s the only oil endorsed by them.
   / Should I use conventional oil, or synthetic oil in my tractor. #72
What kind of oil do they make synthetic oil from?😄. Not being snide...what does it actually mean for a motor oil to be labeled synthetic, given that in this day, that term nearly always refers to a petrochemically derived material?
I could check with Dr. Google but nah, this is more fun.
   / Should I use conventional oil, or synthetic oil in my tractor. #73
   / Should I use conventional oil, or synthetic oil in my tractor. #74
....or Professor Wikipedia....but thanks.
   / Should I use conventional oil, or synthetic oil in my tractor. #75
My backhoe with a cummings has 10 K hrs. dump truck has 300,000 miles neither have ever seen synthetic both fire up down to -10 within a couple revolutions and with probably out live me. I have a cat excavator I did breaK down a put synthetic oil in to try because as soon as it started getting cold out it didn't like starting, I'm not sure if it made a difference or not. Still required cycling glow plugs 3 or 4 times before firing up. Using the proper weight oil with regular oil changes I don't know anybody who's going to put enough hrs. on a small tractor to ever wear the engine out. I'm not going to waste money on fancy oil for my 2610 and it isn't going to let me down because of it.
   / Should I use conventional oil, or synthetic oil in my tractor. #76
A week or 2 ago I paid $23.45 a gallon
for T6 in 2.5 gallon jugs I purchased the
last 4 jugs on shelf and haven't seen any
more as of late.
willy
   / Should I use conventional oil, or synthetic oil in my tractor. #77
Billrog if it takes 3 or 4 times firing the
glow plugs are they up to par? Are they
all working?? Maybe time for new ones??
willy
   / Should I use conventional oil, or synthetic oil in my tractor. #78
The guy I bought it from a few yrs. ago said it was hard starting when the temp got anywhere near freezing so he had new ones installed. Checked again myself and they were fine.
   / Should I use conventional oil, or synthetic oil in my tractor. #79
How often do you have to top them off with more oil??
   / Should I use conventional oil, or synthetic oil in my tractor. #80
I've never had to top of any of my engines in between oil changes & they all run like a top. The hardest thing on equipment engines is probably dirty air filters.
2011 John Deere 844K Articulated Wheel Loader (A50322)
2011 John Deere...
2013 Hamm H11i Smooth Drum Vibratory Soil Compactor (A49346)
2013 Hamm H11i...
2022 Ammann 22/40 Compact Reversible Plate Compactor (A49346)
2022 Ammann 22/40...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A49346)
2025 Kivel 48in...
John Deere 5310 65HP 4WD Agricultural Utility Tractor (A49346)
John Deere 5310...
2021 John Deere 331G Track Loader (A50490)
2021 John Deere...
