Looking for help/advice.
/ Looking for help/advice. #1
homey53
Rutland, VT
Kubota RTV 900, 2016 Kubota BX25 DBL
I have a 2009 Kubota RTV 900, and I'm currently doing some routine maintenance ie. engine oil and filter change, air filter (inner and outer) cartridges, transmission fluid and filter, engine coolant check and lastly, the hydraulic oil & filter for the bed lift. Since that oil only powers that single lift cylinder (I think?), does that need to be the expensive UDT2 Hydraulic / HST fluid? Or would a regular hydraulic oil suffice, like the Standard UDT hyd fluid. Thanks
Tom
/ Looking for help/advice. #2
I think you could use any universal hydraulic oil. But here's what my manual says.
/ Looking for help/advice. #3
I think you are asking: If either SUDT or UDT can be used, why use one over the other?
One answer would be if at very low temperatures the SUDT has a lower viscosity - flows more easily - than the UDT.
If one flows easier than the other then that is the one you want in Vermot winters. Flowing easily means on startup the oil moves faster to lubricate critical close tolerance parts and avoid cavitation inside the hydraulic pump.
I haven't measuredthe low temperature viscosity for myself, and encourage you to do so. Advertising claims and Internet advice are both full of errors - including mine. A couple of canning jars, a deep freeze, a stop watch, and a funnel with a very small neck would probably answer your question. That's pretty much what the ASTM test looks like.
rScotty
/ Looking for help/advice. #4
If you have an HST transmission stick with the Kubota fluid. If you have a manual gear type transmission you may get away with a more generic choice. Be aware that the transmission and the hydraulics probably share the same fluid.
On my BX25DLB the Hydraulics and the HST transmission do share the same fluid, but on the RTV900, there are separate resivoirs for each. Thank you for your reply.
Thanks Richard. I bought my RTV used, and no manuals came with it. I've got to go on line and get an owners manual. Thanks for your reply.
rScotty
Thanks rScotty. I appreciate your reply.
/ Looking for help/advice. #8
The RTVs don't share reservoirs. The hydraulic bed lift has it's own reservoir and pump.
/ Looking for help/advice. #12
Tom
I owned a 2006 Kubota RTV 900 that had 1025 hours on the clock when I sold it.Living in a colder climate I used nothing buy kubota super UTD hydro oil.Made a big difference how the hydro performed verses the other hydro oil I tried ONE time and ONE time only.
Thanks for your reply. As I said in my original post, I was thinking of using Kubota Standard UDT, as opposed to the Super UDT2. Both are Kubota products. I just wasn't sure if UDT was recommended by Kubota for the bed lift cylinder and pump, but since Richard posted a copy of Kubota's recommended fluids for the RTV900, it clearly shows the standard UDT fluid is acceptable. Just being frugal, I guess. $12 difference between the 2 grades of fluids. Not sure of viscosity ratings, but if Kubota says it's OK and they don't show any temperature stipulations, I think I'll go with the Standard UDT. Thanks
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A61568)
2003 Ford F-150...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
HIGH END MINI GOLF CART (A60736)
HIGH END MINI GOLF...
2015 Ford F-350 4x4 Ext. Cab Service Truck (A61568)
2015 Ford F-350...
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
