Stellantis replacing hemi with 3.0L I-6 engines?
Status
Not open for further replies.
   / Stellantis replacing hemi with 3.0L I-6 engines? #2
I had a 2019 Ram 1500 and now have a 2021 Ram 1500, both hemi engines. When I bought the 2019, I thought to myself - in five years, the V8 will probably be gone. may be getting closer.
   / Stellantis replacing hemi with 3.0L I-6 engines? #3
If it makes the power they say, it could be a good replacement for the Hemi. It has what I call “spray on” cylinder liners, which Ford had some problems with on their 5.0 V8’s.
   / Stellantis replacing hemi with 3.0L I-6 engines? #4
You mean Nickasil liners and it was GM, not Ford that had issues in their Vega's. Lots of them burned more oil than gas.
Knowing Stellantis (Pugeot) like I do, I bet they will too.
Don't really matter since pump gas will be 10 bucks a gallon by then.
   / Stellantis replacing hemi with 3.0L I-6 engines? #5
Ford has had problems with them recently, starting in 2018 with the liners. It appears they corrected the problem but the first year was painful for some. It’s called Plasma Wire Arc Transfer Process.
   / Stellantis replacing hemi with 3.0L I-6 engines? #8
   / Stellantis replacing hemi with 3.0L I-6 engines? #9
Well I will be impressed if it is 1/3 as reliable as "AMC's" straight six that Chrysler used for years in some of the Grand Cherokees and Wranglers.
Although a long six they are bullet proof.
My offroad buggy uses a HO 4.0L six out of a Cherokee. 272K miles never had the valve cover off. In the rev limiter at least once every time it's used.
Horsepower always needs fuel so it will be interesting what EPA rating and real mileage will end up to be. I see the lower HP engine recommends 91 octane and the HO requires it so that will cost more. Just the way more HP in a small package needs to be fed. I would assume it is a lighter package though.
Status
2018 Ford F-350 Crew Cab Service Truck (A56858)
2018 Ford F-350...
2015 Chevrolet 2500 Silverado 4X4 Crew Cab Pickup Truck (A55973)
2015 Chevrolet...
NEW Long Forks (A59000)
NEW Long Forks...
1999 Dodge Ram1500 ST Ext. Cab Pickup Truck (A56858)
1999 Dodge Ram1500...
2020 McLanahan 150 TPH USP Sand Plant (A55973)
2020 McLanahan 150...
2015 Chevrolet Express 4500 Shuttle Bus (A56858)
2015 Chevrolet...
