If there are aliens, what will they look like?
   / If there are aliens, what will they look like? #711
Unless aliens know how to warp space/time - it's likely our visitors will be some form of robotic probe. Same applies to us. There is currently no know way for humans to survive the time needed to reach even the closest star systems. Much less simply surviving in space.
I pretty sure this is what spiders are.
“According to the Washington Post…. In a 2016 entomological survey of homes in rural and urban North Carolina, 100 percent of homes have spiders in them.
Spiders are literally everywhere. They can be found in 68 percent of bathrooms and 77 percent of bedrooms.
On average, 61.84 spiders can be found per home. There is probably a spider within reach of you right now.
The global average spider density stands at about 131 spiders per square meter. Some habitats, like deserts and tundra, are home to fewer spiders.”
God is always watching.
   / If there are aliens, what will they look like? #712
(bonus at 15 seconds in)
   / If there are aliens, what will they look like? #713
   / If there are aliens, what will they look like? #714
Actually there is a video of a good size rocket that is sent up (by private individuals) with a camera and the video shows the rocket hitting something, stopping and then falling back to earth.
Takes too much faith to believe in that.
Where is the proof that your alleged rocket hit something? Not talking faith here....need something real.
   / If there are aliens, what will they look like? #715
We are in crazy times when the more outrageous the lie or hoax means more people believe it. ****** also knew this phenomena and used it.
   / If there are aliens, what will they look like? #716
I'm not quite sure of the barometric pressure decreasing with increasing altitude in the flat earth domed system but I suspect it is simply density. Heavier air vs lighter air just like oil floats on water.
There's 'heavy' air down here on the surface that's roughly 78% N2 and 21% O2. It's much different than the 'light' air higher up and inside the dome which is only 78% N2 and 21% O2. It's kind of like heavy water at the bottom of the oceans and light water on the surface even though both are mostly H2O.
One has to know which videos are fake. Obviously another one there, or the private individuals have been exiled to a government island with no communication with the rest of us to explain what that boundary-something was made of. Apparently it's impenetrable and no falling meteor or asteroid (all fakes) could penetrate it or the atmosphere would have leaked out.
Not to wander OT, but I wonder what secret software Lindberg used to follow the Earth's curve all the way to Paris instead of colliding with the atmospheric boundary and crashing down into the ocean. His only forward view was from a small periscope but he made it there ok. Could have used a dimensional warp but no one was there to see it.
btw, I know two military trained and licensed helicopter mechanics who've never operated one in flight. It may be different with airliners and their onboard mechanical/repair personnel who surely do know about software but just won't admit it's there.
   / If there are aliens, what will they look like? #717
I'm just saying the rocket appeared to hit something. Look up "rocket hitting the flat earth dome" on Youtube. (Gofast Rocket 2014)
   / If there are aliens, what will they look like? #718
birds and butterflies don't float.
Wow! I didn't know that! :geek:
somehow butterflies and birds can overcome "gravity" that is able to hold down the weight of the oceans on a 1,000 mph spinning globe.
Beam me up Scotty!
   / If there are aliens, what will they look like? #719
So why doesn't space debris etc. including meteorites hit your so called whatever and bounce off...how do they get past and crash into the Earth? ...(including objects that by chemical and other analysis prove they did not originate on Earth...)
   / If there are aliens, what will they look like? #720
That's your proof? Good grief. Yes, I have seen the videos before, but I sure would need lots more than that to be suckered into a conspiracy theory.
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
iDrive TDS-2010H...
JLG 20MVL MANLIFT (A58214)
JLG 20MVL MANLIFT...
2017 John Deere 5090GN (A53317)
2017 John Deere...
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
