If there are aliens, what will they look like?
   / If there are aliens, what will they look like? #661
Assumptions have to be made in the carbon dating process. Assumptions made on false beliefs in evolution.
My bet that their assumptions are closer to the truth then your beliefs
   / If there are aliens, what will they look like? #663
Explain to me how the atmosphere is contained. Ice dome as well as ice wall? Is there no vacuum in space, or is there atmosphere instead no matter how far one travels from earth. Your presumption of "next to" might be overthought. How can Northern, snowy weather be 'next to' the blazing heat of a Southern drought? Floating curtains of containment there? (lighter than water, obviously)
Explain to me how air becomes thinner and unbreathable at high altitude. Ever been to Pike's Peak? Pretty hard to climb stairs or walk far at the top. Why isn't atmosphere at the same pressure on mountain tops? See above.
Earth's rotation creates day and night. Not switched on like a light bulb. How can there be dawn and dusk if the observer sees all four in the order they do?
Our planet is held in orbit by the Sun's gravity, just like the moon is held in orbit by ours. Does it have an atmosphere too?
As for big words, big numbers that can't fit into one's head or perception also exist if not recognized or acknowledged. Please explain the surface area of our planet in square miles or similar. Surely you have accurate measurements. Be sure to include a map so we can understand which countries/continents are in the center,or nearer to the edge. Or maybe ...
Answer my question posted and then I'll answer yours. ;)
   / If there are aliens, what will they look like? #664
I just did. Nice dodge. Your quick response says you didn't view the videos I posted above. That's how flat Earth theory works. Ignore viewpoints that don't fit one's perception.
Proof that's denied doesn't prove much. Everyone has to believe in something. Bigfoot, unicorns, ghosts, chupacabra, aliens, they're all out there or down here aren't they? Someone believes they are, if that's proof too.
Where is there proof of a flat Earth, unlike other planets that can be observed orbiting and spinning? . Don't use the moon as a one example and say it speaks for all objects in our solar system. Skip the tit for tat BS for once. I don't believe there is anything but conclusions based on personal observation that's keeping flat Earth theory alive.
btw, anyone can ascribe to a modern political trend of: Talk over, shout down, deny, change the subject.
   / If there are aliens, what will they look like? #665
Haven't dodged a question yet. In fact if you have read my responses over the last 40 pages you wouldn't need to ask the questions to answers.
If you are seriously interested in debunking the flat earth I would suggest reading 200 Proofs Earth Is Not a Spinning Ball by Eric DuBay.
Do me a favor and post each of my question and then answer it so it's clear you aren't dodging it. I'll help you again.
Explain to me how a pressure system (atmosphere) exists next to a vacuum system (space) without a barrier?
Prove to me that the earth is rotating.
Prove to me that the earth is revolving around the sun.
Prove to me that water does not seek it's level on the outside of a surface?
   / If there are aliens, what will they look like? #666
Prove to me...prove to me...prove to me....
Sometimes a person just has to say..... WHY.
   / If there are aliens, what will they look like? #667
Water does seek it's level on the outside of a surface. Evident by the visual "Sea Level" around the globe.
The water tries to maintain a constant surface level EXACTLY the same radius from the Earths center of gravity.
There are many disruptive forces that work against that level maintaining tendency. vis. Wind. moon, evaporation, ice. volcanoes, earth quakes etc. but all in all, the oceans do a very good job keeping station at a very predictable distance from "The Center".
   / If there are aliens, what will they look like? #668
Methinks god made stupid people for the amusement of those that can comprehend what is obvious...ignorance can be overcome...stupidity is incurable...
   / If there are aliens, what will they look like? #669
You are kidding, right?
   / If there are aliens, what will they look like? #670
All humor is at someone else's expense.
Except puns
2023 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A60429)
2023 CATERPILLAR...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
2015 KOMATSU WA270-7 WHEEL LOADER (A60429)
2015 KOMATSU...
2013 John Deere 824K Wheel Loader (A56438)
2013 John Deere...
2019 CUSHMAN HAULER PRO ELECTRIC GOLF CART (A58375)
2019 CUSHMAN...
43023 (A59228)
43023 (A59228)
