Starlink
/ Starlink #2,161
Can the second generation router be placed in a sheltered place outdoors? Browsing the SL Reddit several folks report placing their router in a sheltered outdoor location. However, the specifications for the second generation router on the SL website are:
  • Operating Temperature: -22°F to +122°F (-30°C to +50°C)
  • IP54 rated (water resistant), configured for indoor use
I Interpret this to mean the router is not outdoor rated. I just received my replacement dish and router (the first one died) and I want to test it but my best option is to place the router outside because of issues getting the cable into the house. I can put the router on a sheltered porch where it will not get any exposure to rain or snow. What do you think?
If the device won't get any moisture, heavy dust or go outside the temperature range, you'll be fine. Sun degrading plastic could be a bit of an issue long term. "Outside" means wet, freezing & scorching generally. If you can avoid those conditions you should be fine to not kill things or get denied warranty support.
/ Starlink #2,162
It can't be weather exposed. If you placed it in a weather-tight enclosure it would be fine, providing the temp extremes aren't breached.
Rob
/ Starlink #2,163
This ethernet adapter would reside next to the router? I hate to assume anything, anymore.
Lou, the cord going to the new dish does in fact unplug, mine came off in a windstorm the other day haha
/ Starlink #2,164
Yes surprisingly they can be pulled off quite easily on the dish end, at least so on my original and now replacement unit. I may zip tie it or something. The router ends are very snug.
/ Starlink #2,165
It's interesting about that... Some folks report it being so snug that they feel they are going to rip it apart the first time they try to unplug. Make sure your connector is very firmly pushed in next time. The weatherproof connector requires some effort.
Rob
/ Starlink #2,166
Yes, I put some tye wraps on mine to help support it.
/ Starlink #2,167
Here we go. I just received an email from Starlink that my equipment order has been delayed. It is now expected to ship on 3/22
The ethernet adapter and angled roof mount are backordered until late April or early May. I'm going to have to cobble something together temporarily when (and if) the dish does arrive.
I found this mount on Amazon that is supposed to fit the square Gen 2 Starlink dish:
If it's as sturdy as reviewers say, I may use it permanently and cancel the order for the Starlink roof mount.
I'm also encouraged by the Gen 2 router reviews on other forums. The range has improved over the Gen 1 and it is supposed to connect up to 128 devices. If so, I may be able to cancel the order for the ethernet adapter as well.
Well Dishy finally arrived, a full week after the estimated delivery date. Unfortunately, the roof mount, ethernet adapter and extended cable are now backordered until 4/25.
The roof is the only spot I can place the dish and I only want to make one trip up there. Since the mount is backordered, I got this one from Amazon to use as a permanent solution:
I can confirm that it fits the new Gen 2 square dish and allows the cable to be placed inside the tube, just like the OEM mount. It also mounts to the roof with 6 lag screws instead of just 2 for the OEM pivot mount.
I used this clamp to hold the dish & mount together:
It appears the 75' cable will work so I can do a permanent installation without the backordered parts. I will test the location before drilling any holes. All I need now is for the weather to clear.
/ Starlink #2,168
Rob
My Gen 2 system just arrived and the connector easily removes from the dish. So easily in fact, I'm afraid it will pull out on it's own. I'm going to rig something to hold it in place just in case.
/ Starlink #2,169
This has come up before; IP54 should be ok for outdoor use not exposed to driving rain. IP54 is dust tight (5) for two to six hours with no interference with normal operation, and the 4 is watertight to splashed water, with limited amounts of water allowed in.
All the best,
Peter
/ Starlink #2,170
If you’re not aware, the Dish itself will do a scan of the sky to look for obstructions after it is set up and running. See below. According to the app it takes 12 hours.
Good luck with your install and may the equipment be trouble-free. Mine pretty much crapped out after 3 weeks and they sent a replacement. (Both Gen 2) I’m in south Georgia and the dish points due north at about 60 degrees above the horizon.
/ Starlink #2,171
Thanks for the confirmation. I'll order these parts because I used the mount from my now canceled DirecTV dish and it's very loose.
/ Starlink #2,172
/ Starlink #2,173
Thanks!
Others have mentioned premature equipment failure as well. It's advisable not to throw out the shipping container just in case.
/ Starlink #2,174
do you have a picture and calipers? i could prolly design a 3d printed part to fix it, if its simple for a fee.
/ Starlink #2,175
These new rectangular dishes seem to have a lot more problems than the early round ones. I wasn't hearing nearly the amount of chatter about failures and needing support assistance from March through maybe November-ish, but since December it is jumped way up. That's a bummer for all involved.
/ Starlink #2,176
The mount I mentioned above is also a slightly loose fit for the Starlink dish post. I put a wrap of friction tape on it before clamping the two pieces together.
/ Starlink #2,177
The installation instructions say that the dish articulates automatically to seek the best alignment. It isn't clear if this is a one time event during setup or does it realign itself every so often?
If so, the moving parts could become a maintenance issue as they wear over time. Another possible failure point perhaps?
/ Starlink #2,178
My Dish’s position seems pretty stable and fixed. A reboot or maybe a power outage will cause it run through its setup & search routine. And yes I would hold onto the box and packaging for a good while. The return process is simple via FedEx with an emailed shipping label.
/ Starlink #2,179
Observationally, it appears to be something it does on initial power up and then for a few times over the first hours of operation, and then again after power interruptions.
In principle, it should be tied solely to adjusting for the mounting angles to best orient the antenna toward maximal satellite density.
All the best,
Peter
/ Starlink #2,180
There are a lot more square dishys rolling out a lot faster than the old round ones. So even if they had the same defective rate, you'd hear about more issues. Also people tend to get on the Internet to complain loudly about any issues. But they don't go out of their way nearly as much ifcthings work.
The new cheaper to manufacture dishys could definitely be less robust. But listening to chatter without knowing shipping rates or defect rates can give a misleading picture.
2018 Ford F-550 Altec AT37G 37ft. Insulated Bucket Truck (A64556)
2018 Ford F-550...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
JOHN DEERE LOADER MOUNT QT BALE SPEAR (A64278)
JOHN DEERE LOADER...
26in. Bucket with Teeth Excavator Attachment (A64194)
26in. Bucket with...
CATERPILLAR D6R XL CRAWLER DOZER (A65053)
CATERPILLAR D6R XL...
