Oxford Rototiler TM150 does it fit my tractor?
   / Oxford Rototiler TM150 does it fit my tractor? #1
tgrashopper
massey Furgeson 1528
I have and MF1528
HP motor:28.4
PTO motor:22.3
My front loader bucket is 60"
Here are the spec sheet for the tiller:
My dealer is telling me that the TM150 would work with my tractor. I told him I wanted a tiller that would fit my tractor and if I upgrade to a biger tractor one day it would probably be a 35 or 40 hp and that it would be great if the tiller would fit that future tractor.
The TIM150 is 59" and I liked the idea that it match the size of my loader.
I plan on using the tiller for tilling my Deer crop field( clover,Brasica and stuff that deer like to eat) I'll probably used it as well for my personal garden that is around 40feet X40 feet, Small garden for the tractor size.
What do you guys think? will that tiller be to big for my MF1528? I have sent and e-mail to Oxford to asked there opinion as well.
Thanks
   / Oxford Rototiler TM150 does it fit my tractor? #2
Massey Ferguson 1528​
Tractor hitch
Rear Type:I
Control:position control
Rear lift (at ends):2425 lbs
1099 kg
The Oxford web page will not load for me.
If the Oxford roto-tiller has a Category I Three Point Hitch and weighs less than 2,000 pounds it should work fine with your MF1528 and a heavier, more powerful tractor as well.
Your successor 35-40 horsepower tractor may have a wheel width of
66" to 72" and a bucket width of 72".
Tractor hitch
Rear Type:I
1099 kg
sorry not to sure I understand what you are trying to say.
   / Oxford Rototiler TM150 does it fit my tractor? #4
Sorry - I don't either. However - the TM 150 is rated for 35 to 40 hp. Your MF 1528 comes up a little short. It will do the job but you might have to make multiple passes.
I found a guys who has a MF1526 and he is running a 55" tiler. not sure what HP power it's rated for. He told me that his tractor could probably take a bigger tiller. He normaly do 2 pass the first time he create a garden. First passe then wait 1 week and do it aigain to let evrything die. he does not use round up. He also told me that the year after he only need to do one passe.
trying to ensure I will not regret buying it to big
   / Oxford Rototiler TM150 does it fit my tractor? #6
I think you will be making the right choice - buying this tiller. Like you say - it will also work if you decide on a larger tractor.
A suggestion - BEFORE you use the tiller. Either burn off the weeds or mow them down with your lawn mower. They will wind up on your tiller - tighter than a tick. I know from experience. It took the better part of half an hour to cut them off with a sharp utility knife. And I had to do it three times.
Thanks for the Tip. IN the past I used round up before disking with and pull behind ATV disc. The issue is that it's hard on ATV and Round up cost is expensive now days plus it's a chamical that I'd prefer avoid if I can.
2000 INTERNATIONAL 4900 CAR HAULER (A57880)
2000 INTERNATIONAL...
BRIGGS & STRATTON CLEAR SHOT PRESSURE WASHER (A57192)
BRIGGS & STRATTON...
Truck Metal Cargo Storage Box (A55788)
Truck Metal Cargo...
2014 Chevrolet Silverado 1500 (A55973)
2014 Chevrolet...
2025 Electric Cart (A55853)
2025 Electric Cart...
2023 John Deere XUV 825M S4 (A56469)
2023 John Deere...
