Seized chainsaw
/ Seized chainsaw #103
The best insect repellent: Avon skin so soft lotion. It’s made with citronella oil. Foresters have known this truck for years. Doesn’t work on ticks and chiggers (need Deet for that), but works on mosquitoes and no see ums.
My next door neighbor was the patent owner for Deet* and over a drink he related some research findings.
Vitamin C is a good determent but that can't be patented but orange peels contain lots of ''C'.
Then U can buy effervescent 'C' tablets and drink that B4 going in buggy weather. When it's hot and humid you'll perspire and your skin will contain 'C' and thus deter bugs.
"Avon skin so soft lotion. It’s made with citronella oil,"--- and that further confirms his findings and my experience.
* as director or research for Union Carbide and held some 200 patents.
/ Seized chainsaw #105
What made me think that the exhaust side is showing is the round hole at the top center above the cylinder skirt could be the hole leading to the carb for the fuel pump pulse.
The more I look at it, the more I think you're right. Those two ports are on the exhaust port side from the pictures of the 570 that I've seen. Would love to see the other side of the inside of the cylinder and the piston.
/ Seized chainsaw
I am assuming that is the exhaust port in the cylinder in the picture and not the intake port. The problem is either that is the intake port and the saw ingested a foreign object or the piston was installed backwards at the factory. That piston damage is were the anti-rotation pin would be located which should be installed toward the intake port and would set between the intake port and the transfer port in the cylinder.
This saw is 2011. Was used by professional cutter before i got it in 2016. Was working fine before this happened. Foreign object from where? Fuel line? New cylinder is on backorder... still waiting
/ Seized chainsaw #107
Running the saw set to lean will over heat and seize it up also if the muffler is loose and it's sucking air into the cylinder.
/ Seized chainsaw
Here's a pretty good video that shows several causes of scoring. The examples he shows all lean towards raw gas (no or not enough oil). Intake side is scored heavily. I'd like to see the other side of the piston.
Interestingly, around 11:00 he talks about the cold seizure we talked about earlier. Not warming the engine before going full throttle. Not the cause in this case, but a cause of piston scoring nonetheless.
Excellent video! Thank you
/ Seized chainsaw #109
A foreign object could be anything. Especially if it was ever started with the air filter off. Or a broken part. Tip of something. Unless you find it, it's all a guess.
Was the piston scored all the way around, or just on that one side?
/ Seized chainsaw #111
If that is the exhaust port and that side of the cylinder scoring lines up with the side of the piston that is shown, the piston has been installed backwards which could cause the ring gap to snag on the exhaust port.
/ Seized chainsaw #112
The foreign object is the ring anti-rotation pin that came loose from its location in the ring groove, opened up a area in the side of the piston and then jammed between the side of the piston, and the cylinder wall which is the reason for the deep gall mark down the side of the piston.
/ Seized chainsaw #113
On mine the piston and cylinder were scored on the exhaust side, which was most likely from straight gas.
/ Seized chainsaw #114
For seizures caused by overheating, insufficient oil or detonation (which is most of them), the damage is always on the exhaust side. It's because that side of the piston is hottest. So the oil film fails there first, or the ring get stuck first and then overheats the piston and the oil film fails.
If the piston was installed backwards causing a ring to snag in a port it would have failed immediately. From the pics you can see the engine has been run a number of hours.
/ Seized chainsaw #115
Well, I'm no professional but it looks like that piston may have an issue.
/ Seized chainsaw #116
This is the result of running the saw less than 5 min. with a loose muffler. I knew better when the saw started racing as I'd had it come loose before only this time I never stopped to fix it. This is a 30 yr. old saw with hundreds maybe thousands of hrs. as it's bucked over 100 cords of firewood for my use and bucked logs on a landing 12 hrs a day for 3 winters when I was logging as well as fell and cut all the logs for my mill over the last 20 yrs. The ring seized right in line with the exhaust port and stopped the saw dead. I could have got away with just replacing the piston but for $65 the price of cylinder and piston I went for it. This can also be caused by running the saw to lean when when adjusting the carb to exceed the rpm the saw is rated for.
/ Seized chainsaw
Just got OEM cylinder kit. It came with some parts... On the picture: metal plug is for decompression. What is this rubber plug for?
Anybody?
/ Seized chainsaw #118
I drag raced a Yamaha RD400 2-stroke twin for about 10 years. Did all of my own engine and carb work. Pretty heavily modified bike. I had an occasion where I pulled it out of the garage, Gave it a kick to start it, the throttle cable did not return and got stuck full open, and it went from zero to a billion RPMs in about half a second, then PINNNG! It stopped. Seized solid. Upon dissection, the cylinders were scored heavily. It wasn't from no fuel or improper lubrication. It was from cold start to high RPMs instantly.
I can guarantee you that the loggers you know never do that to a cold saw. They give it a pull, it fires up to an idle speed, they pop the throttle a few times, wait a couple seconds, pop it again a few times, then go off to work. Those few seconds of warming it up make a huge difference.
sick bike for the years and the sound 🤤
i agree with your warm up procedure
/ Seized chainsaw #120
A friend used to drag an RD400. I remember seeing him riding it to work the Monday after race day, with the wheelie bar still hooked up to the back.
You had to either love or hate those old bikes, especially with a can on them. There was one parked underneath my dorm window for the entire third semester, not only was it loud but that 2 stroke racing oil wafting up through the window was a real treat. He'd sit there revving the engine for about five minutes warming it up and I know that a lot of people were complaining about it. The owner flunked out but the bike came back the next semester... he'd sold it to one of his friends. The last time I saw it the bike wouldn't start and several people spent a couple of days trying unsuccessfully to get it running. I've always wondered if somebody got tired of listening to it and sabotaged something.
karcher pressure washer (A61567)
karcher pressure...
2004 John Deere 4710 Sprayer (A63688)
2004 John Deere...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A64280)
(INOP) 2013 MACK...
John Deere MX5 (A64126)
John Deere MX5...
ASV RC85 Skidsteer (A66285)
ASV RC85 Skidsteer...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
