Good morning!!!!
   / Good morning!!!! #146,631
2022-03-02, 0845
Just realized I didn't post my daily report!!
23 right now...high in the low to mid 30's...
Got an inch or two of snow late yesterday....I'll do a little clean up in a while
Couple webinars today...good time for a nap
Good Morning Roy
   / Good morning!!!! #146,633
Another wet day here. Each morning when I hear rain rattling on the skylight above our bed, I feel apprehensive about what I will find out in the fields, however so far all except one of the lambs are coping well. Right now out of the window I can see those that are only a week old running around and pinging into the air.
Perhaps it is best to be born when the weather is bad, then things can only get better and you grow up thinking glass is half full instead of half empty. ;)
RNG, if it was a 4-in-1 end of the coupler that was tight, could the bucket hoses have been pressurised by soaking up heat from the sun ?
Wng, glad it was only your toe caps that got scratched. Maybe next time nail clippers would be the safer option :)
   / Good morning!!!! #146,634
66°F and no rain.
Should get my roof finished today. No other plans. Maybe, I just haven’t checked with my supervisor yet
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #146,635
That could have well been the problem, Eric. I prefer to hook the two couplers attached to the implement together, in hopes that any movement of the cylinders will just move fluid from one side of the piston to the other. That should, to my way of thinking, avoid pressurizing the couplers. But a temperature change if the couplers were coupled might still pressurize them, but in this case, I neglected to couple them when I took the 4in1 off. So likely the problem is that the moveable jaw did in fact move, and the little spurt of fluid I saw then I cracked the coupler was the result. So in the future, I'll be more diligent in coupling the lines to the implement together, and also make sure that the way I park the implement immobilizes the jaws in hopes that the pistons don't move inside the cylinders. One of these days I'll get it right...
   / Good morning!!!! #146,636
Happy Birthday to the Mrs, Doug. Enjoy the new pup.
   / Good morning!!!! #146,638
RedNeckGeek -
new member(s), first post, several threads (repeated), nothing to do with tractors etc, (imagine the worst types of spam and links ... like a virus)
it was probably all one person, using several names
Admin cleared it pretty quick
   / Good morning!!!! #146,639
RNG, no smog checks here, gas or diesel.
Burning it off likely last resort
   / Good morning!!!! #146,640
Ken, that’s funny. Most every time we go to Waimea we remark how cold it is Always a few degrees cooler than home due to elevation. Probably in high 60’s yesterday when there. That parking lots sits just about the divide between rainy side and dry side. At times you can literally step in and out of the rain.
IRMC High-End Massage Chair (A57149)
IRMC High-End...
2004 DCT PUMP TRAILER (A58214)
2004 DCT PUMP...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Terms and Conditions (A55272)
Terms and...
2016 Doyle 10T Tender (A56436)
2016 Doyle 10T...
