How many gears should a 1970's M40 Massey Indrustial have !
   / How many gears should a 1970's M40 Massey Indrustial have ! #1
matstones
Massey Ferguson
I've aquired this beast recently but don't know much about it. Mostly it's similar to my late M35x, which has M135 engine
It seems to only have 4 gears, ie 1 and 2, in high and low ranges - I am ssuming it should have more...?
The gearbox is the hydrostatic type with no clutch, so a forward and reverse pedal.
.Also - could anyone tell my what this lever does, the lever by the gearbox dip stick - dead centre of photo, under hand brake rod
Also - if anyone has had the interest to read this far, the power steering doesn't work, any ideas what to look for or check would be much appreciated
Many Thanks
   / How many gears should a 1970's M40 Massey Indrustial have ! #2
Does it change the flow rate of the hydraulics?
possibly - I'll give it a tweak next time I power it up...
   / How many gears should a 1970's M40 Massey Indrustial have ! #4
Many Thanks
It took me about 30 seconds to find this link for a manual (probably not free):
There should be others out there...
   / How many gears should a 1970's M40 Massey Indrustial have ! #5
Many Thanks
Lever is for the 3pt response.
Power steering pump (if like the ag tractors) should be on right side of engine and have it's own fill port (separate oil system) Check oil level by removing fill cap.
GooseNeck Trailer (A52377)
GooseNeck Trailer...
UNUSED FUTURE PDQ 40" LAND LEVELER (A57193)
UNUSED FUTURE PDQ...
2022 MACK GRANITE TANDEM AXLE DUMP TRUCK (A54607)
2022 MACK GRANITE...
2020 Case 5550 Trident (A55315)
2020 Case 5550...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2018 VOLVO VNL TANDEM AXLE SLEEPER (A57880)
2018 VOLVO VNL...
