dstig1
Super Member
- Joined
- Apr 7, 2010
- Messages
- 5,518
- Location
- W Wisc
- Tractor
- Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
Layout the wire first, then slide each section of conduit over it and join them one by one in place. Works much easier if you don't have pulling equipment. The only thing I would advise is before you slip a piece of conduit onto the wire, take a knife/file/sandpaper/deburring tool and take the sharp edge off the inside of the conduit so it doesn't scrape the insulation. If you have a big enough step drill bit (Unibit) you can use that at low speed to do it too. You just need to kill the sharp edge so it doesn't gouge in.
