How far and high can I throw snow?
   / How far and high can I throw snow? #31
I am just plain running out of room to put snow. We've had about 250" so far, still about 80" below our normal. I am stacking it everywhere. I have Kubota B2601 with 24-26 h.p. and am thinking of a 3-point rear mounted blower. 50" probably.
There are times that the blower will be useless with our snow. Half the time it is wet mashed potatoes. You go to pick it up with the bucket and it falls out. Or, you go to stack it and it just rolls back down. I can only stack about 6-7' high. At times with the 54" bucket it is so heavy the hydraulics can't pick it up.
But for the times I can blow the snow my questions are: 1. How high might I expect to blow the snow and pile it up? 2. How far can I expect to blow it, distance wise?
Thanks guys. Time for some Tylenol. Five hours of pushing and stacking today.
My experiences with my blower is that it throws wet mashed potatoes farther than light potato flakes.
I use a blower for the specific reason on not creating piles of snow because piles of snow create bigger drifts. I have a Woods SB54S blower. It will blow snow 50 feet or more. Not sure how high it goes, but I'd have to say it's at 10 to 12 feet high at the top of the arc if I have the deflector all the way up. How far/high the snow goes depends on how I have the deflector set.
   / How far and high can I throw snow? #32
it really all depends on your equipment. i run a larger tractor than you, but i used to run a b2400. when i used that it took more planning than the L3800 i use now. but in general, i start the season, blowing as far as the blower send it, i only move it up to clear the edge, and keep going until the pile is a little above eye level. then i push the piles back as far as i can, and start again. typically we get about 300" of powder per season (not this season, we're waaaay low) at my place. i've never had to truck it away or anything like that.
   / How far and high can I throw snow? #33
Like asking how far can someone throw a rock?
- Who is doing the throwing and what size rock is it?
There no one answer because there’s no one type of snow or snowblower.
The moisture content (density) of snow varies greatly. I’d estimate it can vary 10:1, if not more.
Besides snow type, the throw distance could also be a matter of horsepower, fan speed, feed rate, and/or fan blade clearance.
   / How far and high can I throw snow? #34
Have you considered the Kubota RTV-X 1100C with the front PTO K-Connect blower/plow system? We don't get QUITE as much snow here in northern Michigan as you do there, but 200" or so of lake effect snow isn't at all unusual. I have an RTV-X 1100C, but I couldn't bring myself to spring for the K-Connect system (it's expensive!) when I bought my machine. I just have the Kubota-branded plow and although it's a great plow, when you get to the end of winter you usually end up with the banks pretty high and our little 900' long private road getting narrower and narrower. I think I'm going to buy the K-Connect system and get it installed over the summer so I'm ready for next year. I know this- on a 15*F morning with the wind howling and the snow coming sideways (like today), it's awfully nice to be dealing with the snow from the comfort of that heated cab!
  • Good Post
Reactions: JJT
   / How far and high can I throw snow? #37
I had and used a five foot 3-point hitch blower on my first tractor. 1982 Ford 1700 4WD. I NEVER tried to use it when the temps were above +25F. The snow is too heavy, some times sticky, didn't blow well.
Below 25F the snow was chunky and hard. Go slow - grind it up - blow it a loooong ways.
   / How far and high can I throw snow? #38
I pay no property taxes. No sales taxes. No state income tax. There's three! :)
....and the perm fund check......I caught a 105 lb Halibut, charter fishing out of Valdez......paid for the whole 3 week trip from L48. DaveinFulton
   / How far and high can I throw snow? #39
When the snow is wet or sticky, use PAM or an equivalent anti-stick...makes the snow flow through and life much easier...
   / How far and high can I throw snow? #40
For awhile there you actually had negative taxes due to the subsidies from the oil compananies. Is that still a thing?
And add there is beauty all around, game, fishing wide open spaces, and it isn't California. 😃
If I could talk the missus into it I'd be there tomorrow. We had -18F here this morning, and it was a pretty morning, but nothing like Alaska. If it's going to be that cold I want some scenery
Alaska is great, I've been a few times, even in winter!
An advantage of a 3 point blower is that if you need to move a pile, you can blow off the top at the high lift setting first, then take a second, and maybe third run at it. A hydrostatic transmission makes all the difference, as you can just crawl into it. Just avoid ice chunks embedded in the bank. You can blow slush, it's not great, but works. Just clean the blower out before it freezes in there!
When I switched from loader to blower another big plus was that the loader left a nice sharp bank along the cleared space, which almost immediately drifted in with our winds. The blower disperses the snow, so there isn't a sharp edge to start the next drift.
Wow. I didn't know that. And you have Sarah Palin also.
While I was a fan of Sarah I don't think I'd trade away our current governor. We're definitely not in California!
Giyi Auger (A53316)
Giyi Auger (A53316)
14ft. Deer Gate (A53424)
14ft. Deer Gate...
2017 Ford F-250 Ext. Cab Pickup Truck (A55788)
2017 Ford F-250...
Year: 2005 Make: Honda Model: Accord Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2005 Make...
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
2017 Lincoln MKZ Sedan (A55758)
2017 Lincoln MKZ...
