L2350 won't go into 4 wheel drive
   / L2350 won't go into 4 wheel drive #1
Kipnowski
Kubota L2350
I bought a Kubota L2350 but I can't get it to go into 4wheel , the lever works goes up and down but I don't think it's in 4wheel. Any help appreciated
   / L2350 won't go into 4 wheel drive #2
Take a look at this thread from last week. The L2350 is a similar setup with similar issues - but easier to work on with the front driveshaft tube running below the clutch housing.
screen shot from Kubota Illustrated Parts List :
L2350 front wheel drive.jpgTTH
   / L2350 won't go into 4 wheel drive #3
Check the linkage for loose or missing bolts.
   / L2350 won't go into 4 wheel drive #4
How are you determining that it's not in 4wd?
it can be hard to tell with a tractor; it's not like a truck.
before you "fix" anything, I'd make sure that it's definitely not working
The second post in this thread describes a way to check if the 4wd is actually engaged.....
Did like everyone said , front coup;er was worn, back coupler was broken. Hardest part of the job was driving out the back pin that keeps the shaft cover in place
2015 Chevrolet Express Passenger Bus (A50323)
2015 Chevrolet...
CAT ENGINE (A51243)
CAT ENGINE (A51243)
EZGO (A50324)
EZGO (A50324)
19011 (A48082)
19011 (A48082)
SET OF 48" QUICK ATTACH MAST PALLET FORKS (A51242)
SET OF 48" QUICK...
Kinze 600 Grain Cart (A52349)
Kinze 600 Grain...
