Help on new purchase
/ Help on new purchase #1
Michaellis76
John Deere 1025r
Hey everyone im new to the forum. Need some insight from more experienced users as to which route to go. Im torn between a Deere 1025r or an LS mt125. I would like both equipped with loader, mower deck, bagger system and from driven snow blower.
LS after all equipment is $28,000 they offer 3.9% 84 months
Deere after equipment is $35,000. They offer 0% at 84 months.
both are very nice tractors, the main differences i see are the deere has an autoconnect and drive over mower deck and the ls is manually connected. Also the deere has some worklights and better seat, cruise control etc. Seems like both tractors are very comparable and the attachments are easy on/off for both.
should i consider a slightly used tractor with most of the implements i want or stick with new due to warranty.
How does the LS hold up vs the Deere? Would i be better off taking the 0% as it will cost about the same as the finance charge in the end? Also how is the market for used implements if i decided to hold off on the snowblower for instance? I have some tractor knowledge and experience but not enough to make a decision here apparently. Any tips or help is appreciated as im still a little green in the topic. (No pun intended) thanks!
/ Help on new purchase #2
We are good at helping folks choose a tractor for certain applications or for a certain piece of property.
Which brand tractor, Deere or LS?, will get you opinions, mostly.
Understood and thats okay. I guess im just looking for some input on both machines as for me ive never owned either so dont really know how either would hold up over time
/ Help on new purchase #4
They’ll both perform well and last for an incredibly long time if used and maintained correctly.
Have you driven both tractors? Did one feel better than the other?
Mike
Mike
I did not drive both no. I got a pretty thorough walkaround and demo of both and they both seem to be very good machines. I was leaning towards the LS due to being about $7-8k cheaper, but now that i think of it with 0% from deere vs 3.99% in the long run would be the same roughly. And there are some more convenience features on the deere.
/ Help on new purchase #7
Not having a horse in this race or an axe to grind, I think I would go for the Deere, especially if you plan to be taking the mower deck on and off repeatedly, which you might want to do when doing loader work. Check out the YouTube channel Tractor Time With Tim, he does a lot of work with his 1025Rs. Impressive machines. Good Works tractors does a comparison with a 1025R and a similar size Kubota and his conclusion was, there is no real comparison, 1025R all the way. The only thing I don't like about the 1025R and all John Deeres is the proprietary quick attach bucket compared to the skid steer quick attach everyone else offers. It limits what you can put on the front of the machine.
I own New Holland and Ford, so as I said, no horse, no axe.
/ Help on new purchase #8
some of the attachments you can buy are made for the Deere system I bought a grapple from titan that fits on my loader
/ Help on new purchase #9
Look at what the two are made out of. How thick is the material on the mower deck? Fender hood dash metal or plastic? Plan on doing a lot of loader work? IMO You will want a heavier machine.
How much do you plan on using the machine? Just a few hours a week in the summer and less in the winter.....maybe you do not need a new machine. Lots of money to be lost in depreciation in the first two three years. Maybe for only a couple of hundred hours of use. It is your choice. No matter the machine you chose it is a consideration.
Both machines are made in China so that "made in USA"is not an issue. Just the colour of the paint and what the capabilities of each are. So check out hydraulic flow ,any remotes on the rear? ,lift capacities of loader and 3pt ,yes more is better for both. PTO HP for mid and rear PTOs are meaningful to if you are using this for mowing an acreage. Bag capacity and ease of mounting dismounting and dumping. 28 -35k is a lot of money. Take your time check double check and triple check if need. Doesn't hurt to ask if you [not the sales man] can mount/dis mount anything that you are able to take off of it too
Might wanna check the financing costs out too. That Deere seems to be 4k more after financing.....then again I am doing the math on that. Check it yourself .
Good luck
/ Help on new purchase #10
Since you mentioned a front mount snow blower, if that's a"must have" I would get it with your initial purchase. It may be difficult to find a used blower due to the proprietary nature of front mount blowers.
You should definitely get on each machine and operate it if possible. Happy shopping!
well the resale on the Deere is going to be twice what the LS would be and parts and service is much better on the Deere so it is a no brainer but that being said buy the one you like best. Good luck
Thank you for the reply
Ive been watching a lot of his videos. Very knowledgeable. Thanks!
/ Help on new purchase #13
I own a JD 2025r, a slightly larger version of what you are looking at. I owned a Kubota BX before. The Kubota BX did not have any kind of auto connect deck where my JD does. I like the auto connect deck a lot. I often left the deck on the Kubota when I should have taken it off. The deck on the Kubota wasn’t hard to take off, just not as easy.
JD makes good tractors, the 1025r is very popular, they have a very strong dealer network. I don’t know a lot about LS, from reading this forum I think they are probably good machines also. $7k to 8k is a lot of money but if you are borrowing and the 0% works out the same.
Thanks! I agree as well
I agree, the price tag may be more on the deere, but overall the cost to own after financing when comparing the two is very close. the quick connect deck and more convenience features are leaning me towards getting the 1025
/ Help on new purchase #16
35.000 is a lot for a 1025 in any form. I know things are high right now, but I would keep looking. I know the snow blower is hitting you hard.
/ Help on new purchase #17
Both are very good tractors. I have an LS R3039H and a Deere X584 AWS. Certainly not apples to apples here but the Deere obviously has more engineering behind it and the manuals are better. I'm happy with both tractors though.
Given the fact that your total cost of the tractor is even given the financing, I'd go with the Deere.
Also, get your attachments now. You can usually get a nice discount on attachments at the point of sale vice waiting and who knows if a used snow blower will be available when you want it.
I'd also opt for the cab on either tractor since you're snow blowing.
What is your impression of both dealers? That should be a consideration as well.
/ Help on new purchase #18
The way I explain it to people, is you have a choice between a Honda and a Hyundai, one has years of a history of reliability and good dealer support, the other has to put 'enticements' to get you to buy. I think you see what I value, choose wisely...
both dealers have been very helpful as far as responding quickly and answering any questions. neither have rushed me or pressured me into buying, they both even said I will let them know when im ready to buy. So overall i would be comfortable buying from either one
i actually called to switch the bagger system, they quoted me the dump from seat bagger on the deere, but id rather have the simple 3 bag system. that lowered the price to just over $32,000 which is a little bit better.
2025 Pabreak Hydraulic Vibratory Plate Compactor Skid Steer Attachment (A61567)
2025 Pabreak...
2012 Sunflower 5035-28 Cultivator (A63116)
2012 Sunflower...
2016 Dodge Charger Sedan (A61569)
2016 Dodge Charger...
2012 Keystone Alpine 3500RE 39ft. T/A 5th Wheel Travel Trailer (A61569)
2012 Keystone...
DOOSAN G25E-5 PRO 5 STRAIGHT MAST FORKLIFT (A62129)
DOOSAN G25E-5 PRO...
New/Unused SD Lanch EDLL Mini Skid Steer (A61166)
New/Unused SD...
