Battery Issue
/ Battery Issue #1
Rdr202
Cranston
Mahindra emax22
Was using my eMax22 after shutting it down and restarting I heard a loud pop like a fuse blowing. Checked all the fuses looked for a short couldn’t find anything. Checked battery it was reading 12.34v then I noticed battery was leaking. Replaced battery and started right up.
Battery was only three years old.
/ Battery Issue #2
Was the tractor running at the time? If it was, it may have been caused by a voltage regulator problem.
What type battery was it? Is it still under warranty?
/ Battery Issue
Battery was Exide but was out of warranty. Tractor Supply carries them but I went with another brand. I had been using tractor and I turned it off to secure a load when I went to restart tractor is when i heard to pop and it wouldn’t start.
/ Battery Issue #4
That sounds like a bad cell in the battery, so when it took a lot of amps to crank, pop.
/ Battery Issue #5
I have a 2015 Emax22 Gear. The original battery is a Rocket GB50R. What batteries will replace this to match size. Thanks for the help. Barry
/ Battery Issue #6
No idea what size that S. Korean battery is, but it appears to be 50ah and 450cca. Measure the battery and compare LxWxH to a BCI battery size table and confirm proper terminal type and orientation.
2015 Ford F-550 Crew Cab and Chassis Truck (A64556)
2015 Ford F-550...
Wooden Glider Chair (A64557)
Wooden Glider...
2016 Ford F-250 Crew Cab Pickup Truck (A64556)
2016 Ford F-250...
Horns (A64557)
Horns (A64557)
VOLVO P7110 ASPHALT PAVER (A65053)
VOLVO P7110...
JOHN DEERE 2955 TRACTOR (A64278)
JOHN DEERE 2955...
