Are There Different Ways To Sharpen A Brush Axe??
   / Are There Different Ways To Sharpen A Brush Axe?? #1
CADplans
Elite Member
near Roanoke VA
584 IH 4WD
I have purchased two different brush axes off eBay, a Pexto, and a Collins. The Collins is much lighter, you can swing it faster.
They both have 36" handles, to help keep me out of the thorns.
I have sharpened both of them with a Ken Onion hand held belt sander,, that sander makes them kitchen knife EXTREMELY sharp.
I have tried both of them,, they will not (easily) cut one year old raspberry vines.
Both exhibit the same results, they will slide up the vine, rather than cutting.
I am wondering if there is possibly some other sharpening technique,, ??
Maybe something like filing the edge with a triangle file to give an edge that is serrated with very small triangular teeth??
Or something else?? (no, I am not gonna switch to the gasoline powered brush cutter,, part of this is exercise!! :unsure: )
ANY ideas would be appreciated!!
   / Are There Different Ways To Sharpen A Brush Axe?? #2
I would try a downward stroke, toward the rooted end, rather than sideways and sliding up the whip. If you are just pulling last year's canes, hand snips are the way to go. I sometimes will use a hedge trimmer. I recently discovered where I had stashed the brush scythe. The froe is sound but needs a little TLC. The blade is a hook that is short, sharp, and heavy.
   / Are There Different Ways To Sharpen A Brush Axe?? #4
Wro.ng tool. If gloved hands and lopping shears don't let you reach them without getting into thorns,remove saw blade from extendable manual pole saw and use rope operated pruning shear.
Are you using it right or left handed?
This is the exact Collins I am using, except with a handle, and extremely sharp.
The Pexto is similar, except double the weight, blade width, and thickness.
I can not chop "down",, the axe heads RIGHT at my steel toed boots.
If I go straight down the axe will have enough speed to bury it in the dirt,, or rocks,,
I have tried both right handed, and left handed,, I am rather ambidextrous when swinging.
My nephew was always surprised that I split firewood "left" handed,, even though I am right handed,
I have tried both,, I can not tell much difference.
Typically, I swing the brush axe at the side the plant is leaning toward.
I partially think the axe just does not have nearly enough speed.
It is lighter than the Pexto, but, it is still heavier than a regular single bit axe.
The only really great use that I have found for the brush axe is taking limbs off of a small tree.
If a thorned locust branch is facing my trail, that brush axe will remove a 1" branch with an easy swing,, cleanly.
I do have the rope actuated pole lopper,, maybe that is what I will have to fall back to...
The brush axe was a hope of getting better exercise,, as well as clearing the trail.
   / Are There Different Ways To Sharpen A Brush Axe?? #7
I have found loppers work best. My set has extendable handles and a ratcheting head which allow me to keep my hands back. For removal of briars and bramble I use the box blade with just the scarifiers touching about 2-4” in the ground. Several passes and everything is pulled out.
   / Are There Different Ways To Sharpen A Brush Axe?? #8
A plane old scythe may be just the tool for the job.
When I was at the orchard many years ago I worked with a guy who I believe would be called a "hippie"... he lived with no running water, big long beard, and came from a family with money. He couldn't understand why the owner would go out and pay $1200 for a mower* to get under the trees when he could hire men with scythes. It just so happened that they had raspberries growing under the trees, so when pruning was done they handed him a scythe and let him go at it. At the end of the first day he said to me "I didn't realize how much work this is."
*I said that it was many years ago.
   / Are There Different Ways To Sharpen A Brush Axe?? #9
I've used one of those on blackberries. I did a fast swing at an angle, either right or left handed, just a bit high of where the canes meet the ground. Also a machete with a lanyard attached to the wrist. They got to be sharp though.
I have a HF machete, but, I have not tried it, because the tool is SO dull,, it may take an hour to sharpen.
Also, I wonder if the steel in the HF machete will even sharpen??
EZ-GO Electric Utility Cart (A55851)
EZ-GO Electric...
Year: 2014 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A56859)
Year: 2014 Make...
2023 Load Trailer (A55787)
2023 Load Trailer...
2015 Ford Fusion Sedan (A55853)
2015 Ford Fusion...
2006 International 9400i (A55302)
2006 International...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
