Trailer refurb
/ Trailer refurb #21
I'm not sure how you are installing the screws, but when I did my trailer I drilled new holes in the crossmembers when the deck was off. After putting the PT boards on I put stainless screws up through the bottom. Very easy and clean looking.
/ Trailer refurb #22
I have done this a lot. My advise is to cut off the old bolts with a grinder and use new self tapping trailer decking bolts. This is more expensive but so much easier!
/ Trailer refurb #23
To be honest, a few years ago I would have told you to look next to the muffler bearings. Who would have guessed this was where we were headed.
The muffler bearings are usually beside the bolt stretcher at my local hardware store. I prefer the ACME brand that Wild E Coyote always bought.
I am sorry KennyG I could not resist. Working in a furniture plant we would send the new employee to find the dowel pin stretcher. The new employee would go to an old timer and ask if he knew where the fictitious tool was; the old timer would say, "Joe had it yesterday". After 30 minutes of this the fellow would come back and let me know we lost the dowel pin stretcher. I went through the same thing decades ago...I think we all have at some point.
/ Trailer refurb #24
You can drill from bottom up to align hole with smaller bit.
My trailer has channel iron for crossmembers, so drilling up from the bottom is only an option if you don't care if the screw heads are crooked where they come out of the deck. To get the screw head flat it requires installation from the top. You could lay the boards down, mark them from the underside, then flip them to drill, flip them back over and install the screw, but I think it is easier to use 2 drill motors, one with a drill bit and the other with a #50 Torx bit in it. Lay the board down, drill it, drop a self tapping screw into the hole and hit it with the other drill motor, then go onto the next one.
David from jax
/ Trailer refurb #25
I wouldn't use Phillip's head screws, too eady to strip the head. #50 Torx work better!
Drilling a nrw hole is a lot easier then trying to line up the old holes, and the threads may not start right, and they will strip the threads!
David from jax
I've got some Phillips #3 that fit on 1/2" impact. Used them to screw 2x12 boards three high down both sides of two 500' poultry houses. Screwed into 6" channel iron. But even though those bits are still good, I prefer torx head any type of screw. From deck screws on up.
/ Trailer refurb #26
David from jax
You can drill from bottom. Just stick your bit in from top and lean it until straight. After you drill up from bottom through wood.
On mine I tacked an angle iron on edge of channel and bolted floor to that. I only did two cross members. Each end is held down by a piece of steel.
/ Trailer refurb #27
David from jax
I was trying to say, drill pilot hole from bottom up, then insert screw from top down.
/ Trailer refurb #28
Channels pose a different challenge, but I'm pretty sure the trailer in the original post has angles.
/ Trailer refurb
Is this product worth the effort?
Rust-Oleum Rust Reformer Spray Paint
/ Trailer refurb #30
I've used POR-15 and Eastwood products. This video looks like a reasonable comparison and finds the Rustoleum good but not as good as POR-15. Although they find the Rustoleum a "value leader", I usually brush on the rust reformer, so cost isn't as big a deal as it is with spray cans. The Eastwood product and the POR-15 leave very good brushed on surfaces to paint over.
Best Rust Converter? POR-15 vs Rust-Oleum, Eastwood, Rust Reformer
/ Trailer refurb
What would be best for final coat. Gloss semi gloss or satin?
/ Trailer refurb #32
I replace wood floors with 6" C purlin. Never have to do it again. Roll on paint when your done & sprinkle some balst sand over the wet paint for traction. Or bed coating.
Makes a real good long lasting floor.
/ Trailer refurb #33
Can I use the old holes in the cross member or need to drill new?
Sure if U can figure a way to predrill the wood for accurate alignment and just to be on the safe side for good holding power use self tapping one size bigger.
TIP 4 U
Do as they did in aviation to prevent rusting of tubing,
Pour some oil into any tubing and that it will deter internal rust. It works!
Naturally the tubing ends need to be capped,
On a project (my DIY tractor cab) I simply shaped some wooden plugs and hammered them in after I had added some oil.
Now to trailer floors.
I have a friend that has restored many trailers as a hobby/pastime for pocket money.
He collects old heating oil tanks, cuts the ends off and flattens the cut oval by driving his tractor over a few times and coaxes onto the the trailer frame and welds everything up.
He must have recycled some 30 to date and sells them on the net.
There is a big demand for small utility trailers at affordable prices.
I could not believe how some 'wrecks' could end up as very usable handy trailers.
Naturally a new coat of quickly applied paint helps.
/ Trailer refurb #34
I don't think it really makes a difference. I've used Eastwood Frame Paint which is kind of semi-gloss and Rustoleum Glossy paint and both work well. Whatever look you are happy with.
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
2003 Proclaim Tanker Trailer (A64194)
2003 Proclaim...
2006 Western Star 4900 Concrete Mixer U98358 (A62613)
2006 Western Star...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
