MX5400 breakout/lift strength?
/ MX5400 breakout/lift strength? #1
Jason280
Ga
Kubota L4330
I have a new MX5400 with the standard loader/bucket (LA1065) and 3rd function valve with a grapple. I put about an hour on the tractor a couple of days ago moving crusher run to spread around a new barn, and I've been a little underwhelmed with the lift/"breakout" strength (if that's the correct term) of the loader when scooping crusher run out of a pile of rock. This tractor replaced an '07 L4330, and the 5400 feels like it doesn't have the lift strength of the older 4330. Specifically, when trying to scoop up gravel, it basically wouldn't do anything until you took some of the pressure off the bucket (either backing up, dumping, etc). I can't bury the bucket in a pile of crusher run, and expect to roll the bucket up or lift it. I never had this issue with the 4330, especially not to this extent. My other tractors are an L48 backhoe and 7060, and while I know you can't compare it with the 7060, it doesn't seem to have the "scoop" power of the L48 either.
Specs show this tractor to have a higher lift rating than the older 4330, and I haven't tried lifting anything with a set of pallet forks...but I have been less than impressed with the loader so far. It almost seems like the hydraulic pressure itself is too low....I may need to check and confirm that the hydraulic fluid isn't low.
I guess I just expected this tractor & loader to be noticeably stronger than the L4330, but so far that doesn't seem to be the case.
/ MX5400 breakout/lift strength? #2
How much rear tire/wheel ballast is installed on your new MX vs. old L4330?
How much Three Point Hitch counterbalance are you carrying when do gravel work?
These two weights, especially the TPH counterbalance, make a big difference in what the Loader can lift.
Kubota LA1065 Loader on MX
Height (to pin):111.2 inches
282 cm
Clearance, dumped bucket:85.5 inches
217 cm
Dump reach:26.1 inches
66 cm
Dump angle:46°
Reach at ground:78.1 inches
198 cm
Rollback angle:42°
Breakout force (at 500mm):3102 lbs
1407 kg
Lift to full height (at pin):2275 lbs
1031 kg
Lift to full height (at 500mm):1691 lbs
767 kg
Bucket width:72 inches
182 cm
Kubota LA853 Loader on L4330
Height (to pin):113.6 inches
288 cm
Clearance, dumped bucket:89.8 inches
228 cm
Dump reach:20.1 inches
51 cm
Dump angle:45°
Rollback angle:40°
Breakout force (lift):3,125 lbs
1417 kg
Lift to full height (at pin):2,374 lbs
1076 kg
Lift to full height (at 500mm):1,764 lbs
800 kg
Bucket capacity:0.5 cu yd
0.4 cu m
182 cm
It doesn't seem to be a ballast issue, as its not trying to move or lift the rear. Granted, I need to check and see how much weight is in the rear tires, but I can't tell you how many tons of crusher run and #57 I have moved with the 4330 (using the exact same box blade on the rear).
/ MX5400 breakout/lift strength? #4
Are you keeping your rpms up? If so there might be a problem with the pump. I do believe the bucket is larger on the MX but still it should lift a full load of dirt. How does the weight of the rocks you're lifting compare to the weight of dirt?
/ MX5400 breakout/lift strength? #5
Crusher run can be pretty heavy, especially if wet due to all the fines. The first thing to do if the hydraulic performance seems to be down would be to check the system pressure and make sure it is within spec.
Also what was the capacity of the bucket on the L4330 compared to the MX?
Sent from my SM-G715U1 using TractorByNet mobile app
RPMs are up, and the bucket is actually the same one I've used on the 4330. The 5400 came with the same size bucket as the 4330, except I'm actually using the bucket off the 7060....which I've also used extensively on the 4330.
I need to get some more seat time on the 5400, I just expected a little more....but looking at the chart posted above, looks like the loader assemblies are rated very close to one another.
/ MX5400 breakout/lift strength? #7
I don’t have that issue with my MX6000. The loader is very strong with no hesitation on the curl and lift with full loads of dirt/gravel. You need to talk with your dealer service shop. The 1065 loader is the same on both the 5400 and 6000, and the hydraulic flow rate is also the same.
/ MX5400 breakout/lift strength? #8
I just got the New Holland and I seem to be getting the same experience although I've only put about 5 hours on it mostly moving snow. The two loaders are near equal according to TractorData.com (breakout 3191NH and 3102K and lift 1849NH and 1691K) so I am wondering they are being detuned a little to keep the corporate lawyers happy. My old 1715 isn't in the same league, but it would lift or curl just about anything I sank a bucket into.
/ MX5400 breakout/lift strength? #9
Maybe time to plumb in a gauge on the FEL and see where the relief is actually at and if the pressure is low, bump it back to the factory spec-ed setting,
Or better yet have the dealer do it if new.
/ MX5400 breakout/lift strength? #10
Look up under spec'd loaders on this forum.
Within the last 15 years there have been at least a half dozen threads about Kubota dealers deliberately setting the pressure low.
It's very possible the dealer did it.
/ MX5400 breakout/lift strength? #12
I've been underwhelmed by MX5400 LA1065 combo as well. I came from an '07 L3940 with a Woods loader that I feel like would do more than my MX can. I asked my dealer about it but they said everything was in spec. My L3940 would easily lift the rear end off the ground if I tried to pick something up that was too heavy. MX doesn't even sniff it. I understand there's other factors at play but bottom line is I fell like I downgraded in FEL capacity. I wish I would've done a little more research when I got the MX. I wanted more HP but I didn't want to increase physical size too much. Kubota markets the MX as crossover between the L and M series but in some case the MX has worse specs than the L series.
/ MX5400 breakout/lift strength? #13
My MX4800 can certainly lift the rear tires if I'm not ballasted. A I can lift a full bucket of crusher run and can barely lift pallets of wall blocks. I can lift enough to be sketchy even with the 1500 lb backhoe attached.
Off hand I'd say you have a problem. Either that or Kubota downrated to newer MX tractors.
/ MX5400 breakout/lift strength? #14
Couple of things
First....the loaders are nearly identical.
Second....get a pressure gauge. Just to check.
Third....was the old 4330 a gear trans?
With a gear trans....its instinctive to drive into a pile, push clutch, and lift. Meaning no pressure still trying to drive the tractor foward.
With a HST....its too easy to non-consciously still be applying forward pressure while trying to scoop. This will disappoint sea2summit pointed out. AS the loader lifts, it is actually moving FORWARD. And the weight and pressure of the tractor still tryin to drive forward into the pile is more than the loader can overcome
The MX5400 is a geared, while the L4330 was a GST. The L48 is an HST, and I've never had issues with it (or the L4330) scooping gravel. Maybe I simply need some more time on the MX, but it definitely feels *different*.
/ MX5400 breakout/lift strength? #16
I still think you have an issue. The LA1065 on my tractor is quite strong in the lift category. I have 400# SSQA forks. With them attached I can still lift a one ton pallet to any height. This is the full rated lift capacity of about 2400 pounds. When you’re lifting heavy material in a buck, don’t underestimate the greatly increased weight of a larger bucket full of material. One foot of increased bucket width is a substantial difference in overall weight.
/ MX5400 breakout/lift strength? #17
THe L48 is quite a bit stronger so not really a good comparison.
The MX has basically the same loader as the 4330 did. ANd since both are gear and both kubota...I would think similar to operate.
Id get a pressure gauge and check pressure before trying to figure anything else
/ MX5400 breakout/lift strength? #18
My 5800 with LA1065 FEL was delivered with the hyd. pressure set 10% below spec. The dealer claims it was for "safety & liability" protection. They had no problem setting it to spec though when I complained. Might be something to check.
Although the MX5800 / LA1065 is considerably stronger than my previous L3430 with LA723, like you, I can't bury the bucket and expect it to break out. I can still lift a full rounded bucket of modified gravel though if I use a scooping action and roll the bucket slowly as I push into the pile.
Keep in mind, many of these CUT's aren't designed to be heavy duty front end loaders. Consistently overloading a bucket can shorten the life of the front axle seals on many Kubota models, especially if insufficient rear ballast isn't used.
Although the MX does what I need it to do, it's for these reasons my next tractor will likely be a TLB.
/ MX5400 breakout/lift strength? #19
As others stated check your hydraulic pressure I believe its the same as my L4701 2560 psi I just spread a bunch of #57 in new building I have no problem filling bucket up at 1800-2000 rpm’s had handling I obliviously can’t compare to your past a present tractors but mine is strong I can even pick a ton of stone up on a pallet to about 2.5 to 3ft to move around LA765 loader rated like 1670 lbs max lift.Your mx5400 should be stronger than your experiencing with a max lift of like 2200 lbs would make me think you got hydraulic flow issue ?? Good luck keep us posted on diagnosi.
/ MX5400 breakout/lift strength? #20
I personally would get my own pressure gauge very easy to check pressure.I have an 2019 L4701 when I was shopping I also looked at MX5200 it was like 1800 more in 2019.Only reason I considered it was FEL capacity but to much I liked about L4701 no regrets 20 acres maintenance and tree clearing stump digging with BH 92 been very happy.Hard to imagine the Mx 5400 wouldn’t be up to par unless there’s an issue ?? Your pressure I believe is same as mine at 2560 psi.
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
2013 Infiniti JX35 AWD SUV (A61574)
2013 Infiniti JX35...
CASE 610 Sprayer System 2000 Gallons (A63118)
CASE 610 Sprayer...
2021 ISUZU NPR CAB AND CHASSIS (A63569)
2021 ISUZU NPR CAB...
JAYCO JAY FLIGHT BUMPER OULL TRAVEL TRAILER (A63569)
JAYCO JAY FLIGHT...
2000 ITASCA SUNCRUISER 37G CLASS A RV (A58214)
2000 ITASCA...
