@CalG
a lot of people do not have any understanding of heat transfer.
You hear a lot of "it's always 72 according to my thermostat, why do I feel cold in the winter!" a: radiation heat transfer to the cold wall surface despite the air temp
better though to describe it as heat transfer instead of just "heat". its about the movement of energy, not just the energy.
@Snobdds
your stove produces heat, and that heat is transferred to your body or wall by different methods including radiation, convection and conduction.
conduction to the air touching it, or the pot of water on top
radiation due to the temperature difference between objects ie: stove side and wall
convection is how we quantify a fluid (air) being warmed by the other 2 and then it moving and being replaced with lower temperature fluid (air) due to its density being reduced.
a wood stove is very good at radiation heat transfer, but its not the only thing happening. it's why it feels so damn good in a room with a hot stove on a cold day. the wall surface in the rest of the house is cold and your body is radiating energy to the walls. in the room with the wood stove and its radiation, the wall surfaces are much warmer, plus you are getting heat input into your body by the temp difference between your skin and the stove, not to mention the convection currents of air around it.
aside: my heat transfer professor designed the radiators on the space station! in space all you get is radiation heat transfer but its pretty efficient from your hot surface to the near 0 kelvin of the depths of space.
another aside: silver is the best at reflecting light and gold surfaces are the best at reflecting heat, this is why the mirrors are gold on the new space telescope, its designed to look into the infrared spectrum, which is the wavelengths we feel as heat, but can not see. james webb can "see" in this spectrum.
