Wood stove top fans (heat powered)
   / Wood stove top fans (heat powered)
OP, maybe a pic would help. I only know of stove-top fans that work by heat convective flow and have NO electric parts.
Wires to electric motor can be seen
   / Wood stove top fans (heat powered) #12
I don’t understand the mechanics, but they use disimilar metals to generate electricity. I bought mine more as a novelty than to be functional, yet if I hold a piece of paper up 10 feet away I can see that there is a limited amount of air movement.
To answer the OP’s question; mine works better on the back of the stove as it gets hotter. Often it won’t even work on the front 1/2 until the fire gets good and hot. That’s when I move it to the front, and put a pot on to heat water or supper.
I did buy it as more of a novelty than expecting it to make a difference in heat distribution.
…but a 6”-7” fan spinning at ~2000 rpm has to move some air (depending on blade pitch), right?
I guess my questions are more related to air and fan dynamics, densities, thermal boundaries and how they interact with each other.
I was wondering if airplane pilots might have some similar data?
Energy use vs lift vs rpm vs air temperature kind of stuff…??
   / Wood stove top fans (heat powered) #14
You've never seen a blower mounted on the back of a stove?
I have yet to see a front mounted blower on a stove.
OK, you are not joking. So i will help out. Notice i responded to the “radiant heat” part. It is not radiant heat. Fans blow convective heat. ✌🏼
   / Wood stove top fans (heat powered) #15
That type fan needs heat on bottom and cool on top to function.
So hottest spot on stove, while at same time drawing the coolest air through fan is ideal. So - if rear is hot, that is best since cooler air can be drawn through.
Actually those fans could use a design change where an ‘offset’ exists so the base sets on the stove and the top part is slightly behind the base……
That type fan needs heat to function.
So the answer is to set it where it is hot.
The hotter the setting spot, the faster the fan spins.
The faster it spins, the more hot air it blows……
This is why I based on question on stove top being uniform heat temperature. Assume fan motor gets same voltage applied to it no matter where placed on stove.
With equal voltage to motor, fan might SPIN faster pulling and pushing hot un-dense air, (if at front of stove) but will it move as many pounds of air?
Conversely, pulling cold dense air (fan at back) may make fan turn slower, but is it actually moving more pounds of air?
   / Wood stove top fans (heat powered) #17
Sorry, revised my post. But you want the maximum heat differential to get the maximum fan speed. That would be as my revised post says.
density differences in this case are trivial to fan speed.
   / Wood stove top fans (heat powered) #18
what comes off a stove so a fan can move? A stove only can make radiant heat...it takes another energy source to convert it to convective heat.
Go play pong with someone else.
   / Wood stove top fans (heat powered) #19
My stove top is too small to share with a fan. I have a regular fan mounted on the wall above the stove. It does a good job of moving the heat around. I also have a ceiling fan to move heat from the ceiling.
   / Wood stove top fans (heat powered) #20
A stove produces HEAT Period! Produced as elevated temperatures on the exterior panels of the stove.
How that heat is transported away from the stove surface is a variable.
It could be by radiation. (Deadly Infra Red "Heat Rays ;-)
It could be by Convection. Air currents wafting past the warm stove picking up HEAT and becoming less dense. Rising ever upwards until cooled again through adiabatic mechanisms. ;-)
OR
Heat from the stove could be transported by conductance. Like when you fall against the hot side panel and place your hand between to catch your fall. Burning the skin so badly the top layer sloughs off in a sheet.
But hey! Maybe you have a special wood stove that ONLY makes a never heard of sort of heat called radiator heat.
IDK, I'm guessing.
And if one is curious to better understand the difference between HEAT and temperature, try this.
Heat up your kitchen stove to about 450 degrees F.
Open the oven door and stick your hand in. THAT"S TEMPERATURE you are feeling all over the skin of your hand. (a combination of conductance and radiative heating)
Now, Touch the metal rack with your finger. Feel the burning flesh? THAT"S HEAT! (PURE conductive heat transfer)
convection occurs WITHIN a given medium, Conductance occures between different mediums, radiation doesn't require a medium, only a difference in temperatures between two separate surfaces.
All I know, is the "heat seems to all go upstairs". ;-)
2024 Ford F-350 Super Duty XLT FX4 - Like-New, Loaded, Only 780 Miles (A52128)
2024 Ford F-350...
2003 Honda Element (A50324)
2003 Honda Element...
Heavy Duty Skid Steer Auger ECAG W/ 6", 12", and 14" Bits (A47384)
Heavy Duty Skid...
1996 Fertilizer Tender Trailer (A50514)
1996 Fertilizer...
John Deere 603 3 pt Mower (A50514)
John Deere 603 3...
1985 Corn Husker Hopper Trailer (A50514)
1985 Corn Husker...
