Bobcat CT4050 Rear Hydraulic Coupler
/ Bobcat CT4050 Rear Hydraulic Coupler #1
Jeff R.
Bobcat CT4050
Anyone know what style of hydraulic couplings are used on the CT4050 rear hydraulics? I have the operators manual, service manual and have searched the parts catalog, but it says nothing about the specs of the coupler. Very frustrating.
/ Bobcat CT4050 Rear Hydraulic Coupler #2
Should be: https://www.amazon.com/s?k=1/2+ag+quick+coupler&crid=2GZQ9CXXW2PJM&sprefix=1/2"+ag,aps,168&ref=nb_sb_ss_ts-doa-p_2_6
Identification:
Thank you, I will try it.
Thanks for the help. I purchased a Walco log splitter and it came with male couplers. Using the chart you posted, these are ISO 7241 and not the ISO 5675 that I need.
/ Bobcat CT4050 Rear Hydraulic Coupler #6
The Walco came with the 7241's, or the tractor?
Have no idea what the tractor has yet. The splitter came with 7241's.
/ Bobcat CT4050 Rear Hydraulic Coupler #8
OK.. let us know when you find out. I'm curious is Bobcats are equipped differently than Kioti's, seeing how they are supposedly the same tractor and all. Your's being bigger than mine might mix things up though.
Another source online has said his are 1/2" AG. I will confirm and get back to you.
I ordered some 1/2" AG from Summit. They didn't seem to work at first, but I think the tractor fittings had some debris or roughness. Eventually got them to work.
Thanks
/ Bobcat CT4050 Rear Hydraulic Coupler #11
Thanks
Make sure you relieve as much pressure as you can before trying to connect, otherwise be really strong while pushing :)
Pressure was not the initial problem. I was able to press the poppet on the tractor side. Seems like the coupling needs to be in the exact position before it goes in.
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
2004 VOLVO VHD TRI/A CEMENT MIXER TRUCK (A59906)
2004 VOLVO VHD...
2014 INTERNATIONAL PROSTAR+ (A60736)
2014 INTERNATIONAL...
IRTPL LIFT (A58214)
IRTPL LIFT (A58214)
Sterling 9500 (A61307)
2006 International 7400 SFA Terex Hi-Ranger 6TC-65 65ft. Insulated Bucket Truck (A60352)
2006 International...
