tradosaurus
Super Member
- Joined
- May 8, 2017
- Messages
- 5,534
- Location
- Texarkana, TX
- Tractor
- Kubota MX5400 HST, heavy duty bucket, 3rd function, R1 tires (rears filled), 2 remotes
What about a 2wd tractor?
I've got both, and each has it's purpose. I've also been stuck with each one, when three wheels are pulling and the bucket is helping, I've probably gone a bit too far.What about a 2wd tractor?![]()
Now yer just bein sillyI know RWD with a true locker is better than 4wd with opens for not getting stuck
If I'm paying for 4wd I want a locking rear and center. The only way you get stuck with that set up is to be on the frame. Most people don't want to hear their 4wd system is crap but I've seen it on many a slippery boat ramp. 2wd with a locker drives out and 4wd with no lockers sends all the power to one wheel.
Thanks, the day you admit you're wrong is the day I know your account was hackedNow yer just bein silly
HahahaThanks, the day you admit you're wrong is the day I know your account was hacked. I'm probably wrong but this has been my experience with vehicles and getting stuck. Long live lockers!
I wonder who makes "the Best" Electronic Diff Lock?
Wheel speed sensing independent wheel braking systems with all open differentials. (Even the transfer case gearing should be open)
The Audi "Electronic Stabilization Program" Was very effective.
As an Aside,
I ran an 2000 Isuzu Trooper until only last winter. (Sold it and got the Tacoma.)
That drive system, TOD or Torque On Demand , was very effective.
In high range, the Transfer ratio was "proportioned" front to rear through a proportional application of hydraulic pressure on a multi plate wet clutch within the transfer case. It worked very well along with independent wheel spin control through the anti-lock brake system. In low range, the front real split was locked together by hard gearing.
With good winter tires, that Trooper was about unstoppable.
In my experience, it was a very good system!
