Adding aftermarket snowplow Cylinders to AF10 front blade
   / Adding aftermarket snowplow Cylinders to AF10 front blade #1
furface
Enumcaw, Wa
Cub Cadet
I have 2014 1025R. I already have a summit 3rd function mounted on the loader. I have a AF10 front blade. The AF10 blade has mounts already for the optional hydraulic angle adjustment unit. The local John Deere dealer wants about $1000 out the door for the optional hydraulic angle adjustment unit kit. From what I see the kit includes two cylinders, two elbow fittings, and two hoses with ends, hydraulic quick disconnects, and 5/8 mounting pins.
Aftermarket cylinders that fit run $99 - $130. The local tractor supply has the hoses, fittings, and mounting pins.
So ... I can put this together myself for around $400 or less.
Am I missing something here? :unsure:
   / Adding aftermarket snowplow Cylinders to AF10 front blade #2
Go for it.. Surplus Center has been my "go-to" for cylinders and some hyd. hoses.
Welcome to TBN.
Pics are welcome when you getRdun
It was pretty simple. Of the shelf from Tractor Supply. 2 Maxim Single Acting Snowplow Cylinder, 1.5 in. Bore x 6 in. Stroke, 1.5 in. Rod Diameter, Manufacturer Part # 288500, $79.99 each. And 2 - CountyLine 1/4 in. x 36 in., 5,000 PSI Hydraulic Hoses for $16.99. I also picked up 2 - 5/8 x 2 1/2 grade 5 bolts, 2 - 5/8 x 4 1/2 grade 5 bolts and 4 5/8 - 11 Ny-loc nuts.
At NAPPA I got two hydraulic elbow fittings with a straight male 1/4 NPT thread and a swivel female NPT thread. $5.99 each.
From Summit Hydraulics I ordered two 1/4" Ag Hydraulic Quick Connect Couplers, 1/4" NPT Thread. $9.96 each plus shipping.
So about $250 for it all and it is working great.
   / Adding aftermarket snowplow Cylinders to AF10 front blade #4
Great to hear it was a successful installation for you! My uncle might do this mod as well. We'll just finish installing the bumper and jeep accessories on the Wrangler this week.
CATERPILLAR 312E EXCAVATOR (A52706)
CATERPILLAR 312E...
King Kutter TG72 Rotary Tiller Tractor Attachment (A54811)
King Kutter TG72...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2014 Ford Transit Connect XLT Cargo Van (A55852)
2014 Ford Transit...
2023 John Deere 332G Skid Steer (A53485)
2023 John Deere...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
