What attachments should you use on a tractor to clear land.
   / What attachments should you use on a tractor to clear land. #101
That is the going rate down here, call and see...
Did you do as I said and talk to actual forestry people? Also did you check into cost/share funds with state forestry or NRCS? I’m giving you free professional advice.
   / What attachments should you use on a tractor to clear land. #103
I look at it as being a lot of good information on this thread for future reference if it comes up in a search. Over 10 yrs ago I found a thread on tbn on a search not having anything to do with tractors. Never even knew this forum existed before hand.
Whoa, who said anything about a loaded ctl, mine was a low hr used open rops skid steer with minimal options for a fraction of a new ctl. I bought wheel spacers and tracks for it cause the sand was killing me. I bought a few U S manufactured attachments from a newer startup company for less of the cost what they will cost me now. If I lived in Florida I'd give you a hand if you wanted it, for a lot less than your quotes, or I'd sell you my entire setup, after a demo of course. Best of luck on your endeavors 👍
When I find one for around what I paid for my L3301, then it would be worthwhile..
Call and you will see its much higher in this market...
   / What attachments should you use on a tractor to clear land. #106
Ritchie Bros has big equipment auctions in Florida. good luck.
Royal Auction Group also has some good deals...
   / What attachments should you use on a tractor to clear land. #108
107 replies and still no description of what needs to be "cleared", and to what finish level. Some people can't get out of their own way, or even describe the obstacle in front of them.
Whatever the fires left behind..
Guess you didnt see it at the start.. Its basically the burnt out trees and the invansives that are coming up..
   / What attachments should you use on a tractor to clear land. #110
But you didn’t talk to the people who can provide cost/share funds? Who are you calling? Did you talk with the Forest management professionals that I described? You have been asking for advice and I am a professional forester of 40 career years who is very experienced with wildfire rehab. You refuse to listen and take my advice, so knock yourself out and learn the hard way.
UNUSED PABREAK RGB240 - 84" ROCK GRAPPLE BUCKET (A57193)
UNUSED PABREAK...
10' HYD POLE SAW (A57192)
10' HYD POLE SAW...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55315)
Michelin CARGOXBIB...
2003 Big Tex 10PI...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
CATERPILLAR D6R XL HI-TRACK CRAWLER DOZER (A52707)
CATERPILLAR D6R XL...
