B3350 REGEN PROBLEMS & FIX
/ B3350 REGEN PROBLEMS & FIX #1
Jhavens22
Kubota B3350
Ok. If you are having B3350 Regen problems, Kubota can't fix it. BUT, after arguing with the dealer etc. I found a way to bypass. Text me.
/ B3350 REGEN PROBLEMS & FIX #2
Kubota's lack of support for this problem in that tractor is why I crossed Kubota off my shopping list. Kubota could have easily replaced every single B3350 with a new tractor, removed the DPF and donated the tractors to third world countries without much damage to their bottom line. Instead they let their customers carry the burden.
/ B3350 REGEN PROBLEMS & FIX #4
Is this under warranty?
There is no warranty on them. The reformer was and is a continual issue. dealers cannot sell them anymore, in fact, they aren't even produced and have not been for a number of years. Kubota really screwed the pooch on that tractor.
/ B3350 REGEN PROBLEMS & FIX #6
Oh, darn
Sounds terrible
I learned about this tractor and issue on a YouTube video about the 5 tractors to avoid. My immediate thought was if Kubota didn't step up to the plate on this one, how do I know that if an issue comes up in the new tractor I buy, they wont also leave me on the hook?
/ B3350 REGEN PROBLEMS & FIX #7
You were smart, thankfully it looks like someone figured out a work around
/ B3350 REGEN PROBLEMS & FIX #8
As usual, you have no idea of what you are posting, yet you post it anyway.
The B3350 tractors Reformer system has a LIFETIME WARRANTY and is easily reparable. They were produced from 2014 to 2020, production ended with the introduction of the LX3310.
PSB-2021-050-E; "Extend reformer system warranty for the lifetime of the machine The reformer system components will be warranted for the lifetime of the machine. A failure with obvious and deliberate customer interference will not be warrantable. Correct operation and understanding of the emissions system by the customer is vital to ensuring longevity and reliability."
/ B3350 REGEN PROBLEMS & FIX #9
Actually, reformers are still available and Kubota has extended the warranty of the reformer and any other emissions parts damaged by a failed reformer for the lifetime of the tractor, regardless of ownership trail.
SDT
/ B3350 REGEN PROBLEMS & FIX #10
Bingo.
In my opinion, Kubota did the right thing, albeit after an inexcusable delay.
I had decided to replace my 2018 3350 before the 5-year emissions warranty expired but have now decided to keep it. Where else can one find a lifetime "emissions" warranty?
SDT
/ B3350 REGEN PROBLEMS & FIX #12
SDT
I wasn't aware of that. I thought they played the end game with them. Does the refit require a dealer to do it or can you do it at home? Really not germane to me as they are way too small for my intended uses anyway.
Least Kubota did the somewhat right thing. Kind of wished they had done the same with the weak pto brakes on the M9's instead of issuing an RO but not notifying owners of the refit. As it is, mine are way out of warranty and I just run an overunning coupler on freewheeling implements if there isn't one built in.
Not gonna pay shop time for a split to access the wet pack to have the pack upgraded. Would be especially expensive on mine as they are cab models.
/ B3350 REGEN PROBLEMS & FIX #13
The PTO brake upgrade was change made during the M9960 model run. Of course, my M9960 SN is a bit before the change was made.
I have seen catastrophic PTO brake failures from M series tractors. Not a pretty sight.
SDT
/ B3350 REGEN PROBLEMS & FIX #14
Dennis even showed me the RO advisory when I was there one time.
I'm extremely careful with both of mine, always cognizant of what the pto is doing when I disengage it which is why on any implement I own that lacks an over running clutch, I have the 100 horse capacity clutch on the pto stub. In my favor is, I only own 2 implements without, my Landpride Bat Wing and my Kuhn Masterdrive rotary rake. Everything else is internally clutched so no driveline freewheel at all.
Would I want it upgraded, not really because I'm aware of it and take the necessary steps to mitigate it. Besides, because it entails a split, it would be very costly to upgrade the clutch.
I thought it was in poor corporate taste for Kubota not to inform owners of it. Actually Dennis fore warned me about it a long time ago so I was aware.
Easy answer is always run an over running ratchet clutch on the drive stub, something that Kubota should have addressed and didn't. The other issue is purchasing a clutch of sufficient capacity. Most of them are only rated for 50 horse pto maximum. I was lucky to find one rated for 130 but it wasn't cheap. Of course it was cheaper than a grenaded pto clutch.
If I ever sell either unit, or both, the clutches will go with them.
/ B3350 REGEN PROBLEMS & FIX #15
From another thread on Kubota regen problems:
extended coverage is only going forward starting at the date of the policy change. They are refusing to reimburse me for mine since it occurred after the 5 year warranty and before the "change in policy". I'm out $3750 for parts plus labor (so over $4K . . . I thought it was more before the dealer sent me the work order). I wonder how many others forked over the money for the repairs . . . if I'd have waited for 6 months or so, I'd have gotten the repair for free.
Lifetime warranty= Life of the tractor (PSB-2021-050-E) dated 03/31/2021
I'll stand by my opinion of Kubota and will not buy a new one.
/ B3350 REGEN PROBLEMS & FIX #16
Bingo, and exactly what I said. Warranted for the lifetime of the tractor regardless of ownership.
I have a copy of the bulletin.
SDT
/ B3350 REGEN PROBLEMS & FIX #17
So there is a policy coverage gap?
Maybe it can be argued as it seems they recognize there is an issue
/ B3350 REGEN PROBLEMS & FIX #18
If you bought an early model (2013-2016) and your regen system crapped out on you after the five year warranty and before 03/31/2021 you are left out in the cold by Kubota. As it stands, it took lots of bad press and 8 years for Kubota to address the problem and stand behind their product. They lost all kinds of credibility in my book and I will not buy a new Kubota because of that. It shouldn't be forgotten, there are a number of owners whose tractors logged as many shop hours as they did work hours. Does Kubota pay to pick up and delivery for warranty service?
/ B3350 REGEN PROBLEMS & FIX #20
As previously stated, the delay in extending the warranty was inexcusable.
No, Kubota does not pay for pick up and delivery, warranty work or otherwise, nor does anyone else. Some dealers will. Mine does not.
I certainly have no issues with your decision regarding Kubota purchases. Everyone should do as they like.
SDT
2012 Chevrolet Equinox AWD SUV (A64557)
2012 Chevrolet...
2014 CATERPILLAR 924K WHEEL LOADER (A65053)
2014 CATERPILLAR...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
2025 SDLanch SDLL60 Mini Stand-On Track Loader Skid Steer (A64553)
2025 SDLanch...
2016 Chevrolet Silverado 3500 Auto Crane Service Crane Truck (A64194)
2016 Chevrolet...
2012 POLAR TANK TRAILER (A63569)
2012 POLAR TANK...
