New tractor arriving this Friday. What do I need?
   / New tractor arriving this Friday. What do I need? #12
Not sure of your location....maybe block heater and tire chains,easy to use diesel fuel container.
Now there's some good ideas!
Any tricks for attaching a shovel vertically....tool holder clamps?
   / New tractor arriving this Friday. What do I need? #15
Not to throw icewater on a set of grab hooks but, if you get them, you need to be cognizant about where on the bucket you place them, especially if the bucket is a light duty material bucket. Placing them in a non supported spot can bend the bucket sheets. If I need something moved, I welded a set of hooks directly to the SSQA frame. The closer you are to the center point of the loader frame, the more lift you have.
Don't get enough consistent snow up here.....some years, but not like Michigan or something...
   / New tractor arriving this Friday. What do I need? #17
I am in N AZ and the land is dead flat. I will be using it for general property maintenance, moving dirt and DG, clearing weeds and rocks, plus livestock cleanup. Pretty light duty I think.....
I lived in N AZ and found the following things to be used the most: loader, rear blade for snowplowing and road maintenance, rotary cutter for mowing, canopy for shade when mowing, and supplemental work lights mounted to the canopy or ROPs.
   / New tractor arriving this Friday. What do I need? #18
New tractor arriving this Friday. What do I need?​
a camera
   / New tractor arriving this Friday. What do I need? #19
During the years I lived in Flagstaff and Show Low we got plenty of heavy snow. Are you somewhere else in N AZ?
Between Prescott and Flagstaff 4500 ft elevation.
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
CRAFTSMAN TABLE SAW (A54757)
CRAFTSMAN TABLE...
(2) SHOP VACS ON PALLET (A58374)
(2) SHOP VACS ON...
Toro Dingo Mini Skid-Steer Mounting Plate (New/Unused) (A59225)
Toro Dingo Mini...
2012 LEDWELL 48FT DOVETAIL TRAILER (A58214)
2012 LEDWELL 48FT...
