code 20 ECU
/ code 20 ECU #1
coupman35
Gold Member
Northen Ontario
Now a L4060 had B2650
Can any one help me whit this the tractor was out side for a few hr now it will not start it givinf mw a code 20 something about the ECU no comunication
/ code 20 ECU
Funny i just found that thread i check my fuse they a test ok .Then i tryed to clear the code but nothing i keep checking in the morning .The tractor was outside -20 i was getting cold .Next door friend came and help put the tractor in the garage it nice and warm in there .
/ code 20 ECU #4
/ code 20 ECU
ok get back in garage this morning try to start the tractor and it did code is not there any more .
Now am going to check under to see if there any lose saw a few connection some on the HST pedal and some on the other side .where shude i check first.
/ code 20 ECU
Any one have the wire diagram of where is the ECU located
/ code 20 ECU
Here is what i found a pic of the ECU
/ code 20 ECU
Yep found it Thanks Went under and check for lose wire or connection but every thing look ok push all the connecter yesterday went out plow for abit and it all good .The tractor alway in a headed garage and i had to but it out for a few hr it -25 .I guess it did not like . lol
2020 FREIGHTLINER CASCAIDA 123 6X4 T/A  SLEEPER TRUCK TRACTOR (A59908)
2020 FREIGHTLINER...
2005 CHANDLER 500 BBL FRAC TANK (A60736)
2005 CHANDLER 500...
2006 FRAC TANK 500BBL WHEELED (A60736)
2006 FRAC TANK...
TAYLOR POWER SYSTEMS SKIDDED GENERATOR (A60736)
TAYLOR POWER...
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
